Hi All. Can you guys recommend a decent quality BNC to RCA cable? I had an Empirical Audio Freeway 2 which has digital output but is BNC terminated. My X-DAC needs RCA input. I currently use an el-cheapo BNC-to-RCA adapter (as in the attached pic).
I would like something a bit more robust. Also, the cable from the Freeway is only around 12cm long and thus the BNC-RCA cable would add the requisite length (for equipment positioning freedom). Does not need to be a top-of-the-line cable, just something decent and relatively inexpensive.
Thanks and Cheers,
X
Thanks and Cheers,
X
