Researcher
The BT 5 is in this case just marketing blabla. The BT Chip (which is also used by other devices like earstudio) is certified for BT 5 (but the certification was easy as this kind of device needs to implement nothing new for BT 5 - so qualcomm just had to spend a few bucks for recertification)
If you read the Bluetooth specifications (or at least on wiki whats new on BT 5) you notice following;
BT 5 brings big improvements for BT Low Energy. This is good for Stuff like Fitbit and so on.
But for A2DP - that what is used by BT audio Receivers - the communication is done by Bluetooth BR/EDR classic.
And this wasn't changed since BT 4.x on receiver side or on the protocol
So for audio BT 5 is no improvement like higher Datarate.
Yes, the sender is allowed to send with a higher output power in classic mode. But this "feature" does not need a higher Protocol number on Receiver side. Also Receivers with BT 4.x (or even older) profit if the sender is transmitting with more power.
So:
BT 5 in smartphone (or other sender) = good.
BT 5 on receiver side = just marketing
(for classic stuff. For LE Stuff it's great)
BTW: it's BT 5 not BT 5.0.
Bluetooth dropped it's Point numbers starting with BT 5
BT 5 (i am almost sure 5.1 will be released. You will use 5.0 then. Whether or not i am right, this is not the topic we are discussing about) To be honest, you wrote many WAFFLES here. BT 5 is currently a must-have feature due to several reasons;
Bluetooth 5 provides the high speed in terms of the speed between packets. In reality, the speed is in terms of link speed. Historically, BLE was capped at a 1-Mb/s data rate; that’s doubled to 2 Mb/s with Bluetooth 5. This means low latency, while watching a movie. Moreover a Bluetooth 5 radio at 2 Mb/s will see a big advantage in application throughput when placed the same distance apart. This means you can hear clearly what you are on at longer range. Many people here complain about temporary loss of connection and clarity, while their phone are placed into back-pocket. This will kill such an unacceptable situation.
I got Iphone X with BT 5. Of course, i would like to invest in not crappy tech but future.
anyway, my question is still there, is there anyone here who can say the Gets`s connecting range (ft) with/without any obstacle?
