Bluewave Audio Get - Bluetooth 5.0 AptX HD 24 bit amp/DAC
Discussion in 'Portable Headphone Amps' started by Karendar, Aug 5, 2017.
8 9 10 11 12 13 14 15 16 17
19 20
  1. Karendar
    I can measure it tonight for you once I get home if noone does it before then... My gear is on my desk. It's not super long though, it's pretty flush on my SHP9500s... I'd say approx 5 inches long.
  2. SuperNovaGoesPop
    Hey thanks. Could you also do me a favor and see if the included cables are long enough to clip the Get onto the metal part of the headband of the SHP9500? That's literally what my intention would be.
  3. Karendar
    6.5 inch. Haven't had time to take a pic this morning, but it does exactly what you want to do, as that's how I do it :wink:
    SuperNovaGoesPop likes this.
  4. SuperNovaGoesPop
    Awesome...thanks!
    I have a Fidelio M1 over ear with a little pigtail cable hanging off of it...absolutely perfect for using the Get to make it legit wireless. Dunno if I want to spend more money to do the same with bigger headphones just yet vs just using the Get as a clip, but thanks a million for letting me know all of that; sounds like a go.
    Also...mine doesn't cut out when cupped or put in a pocket, but walls and reasonable distance are not the Get's friend. I don't care as much since I bought it to use with my phone, and my phone never really leaves me or my side anyway.
  5. Pierre111
    Hi There, you can find what version you have if you have a windows computer. You go to the deice manager, then in the sound categories you Go to details and you should choose Hardware ID. Yo will see this:
    The number after PID_ is your version. 001 is High gain, 003 is low gain. For info the 4 digit Hex number is the serial. I'll see what I can do to find this info on a Mac, it's also there somewhere.
    Pierre
  6. SuperNovaGoesPop
    Go figure, mine has the 0003 number listed, haha. I was able to get an email response that also said the box should now have a sticker on it that says R00 for high gain
    Go figure, mine came up as a 003 number. I also had an email correspondence tell me that there's now a sticker on the box labeled R00 for the high gain model and R01 for the low gain model. Since mine was an open box purchase...who knows, haha. But the box didn't have a sticker on it so I assumed it must have been one of the originals before you guys had two versions. I might just return it for peace of mind to be sure of what I have.
    Massdrop has the Get at $85 with the included impedence adapter; does thst mean that this is the high gain version?
    Thanks!
  7. Pierre111
    Hi, you might have been answered unclearly, only the Hi Gain version are labeled with R00, the low gain should not have a label. The Indiegogo units where all Hi Gain and unlabelled as well. If the number says 003 I confirm you can be positive that the one you have is the lower gain version. The next Massdrop shipment will be Hi Gain.
    Pierre
  8. SuperNovaGoesPop
    Beyond awesome to have solved this. Yeah, I'm just going to grab one of the massdrop units since the price will be basically the same as what I bought off of ebay. I really do like this little device and think that you have a good product outlined despite some quirks; hoping for a 2nd generation at some point from you and further refinements. I also like the overall look/design of these compared to the competition.
  9. Cane
    Regarding the latest update. I would say that it is a step forward and back, at the same time... The issue with loosing sound when "cupping" the device, seems to be fixed, and the device seems to recover when out of range, instead of loosing sync (but I haven't really tried to, so I don't know what will happen). The step backward, is the fact that moving around produces a short skip/loss of sound, every time i angle away from line of sight (it does recover immediately again, but at the same time, it can happen again as soon as I change angle again)... it wasn't as picky before (at least not, since getting a replacement for my first unit, that would have a loss of sound even at 30cm (1 foot) distance).
    I am thinking of going back to the "2018.02.13" version again. I do sit still, for more time then walking around (keeping my phone in the same position, not taking it with me), but the sound cutting out when moving around is more disturbing...
  10. Darkestred
    I have been using the update for a couple days now. I cannot say i have had the walking around issues. I have walked around with the phone on me and with phone out of my pocket and idle. If it helps, I have a Sammy S8+.
  11. Cane
    You have a new phone. The team have acknowledged the fact that they didn't have the resources to test on older decices. I have a Samsung Galaxy Note 4, so quite a bit older...
  12. chadsfake
    I am using with Samsung s7 and so far find the update a good improvement
  13. Darkestred
    Yes. I can see that i have a newer phone than you with this piece of information. I was simply letting you know my experience.
  14. Cane
    And I just pointed out that they haven't tested on any units with older hardware or OS, than basically the latest iPhone(s) and a few Android phones. People with the most problems, seems to have older phones, and like I said there's a reason for that.
  15. Darkestred
    Yes. I read that email before i installed the firmware. However, it said nothing about older phones. Just that Samsung phones got great feedback.
    "Our beta testers who had dropout issues reported a great improvement in dropout rate, especially those using Samsung smartphones. Do let us know of your results by email!"
    I don't know if you're giving me attitude or your text is just misleading. I can't predict what phone you have just by you saying you have issues. So, without assumption. I let you know that i didn't have those issues, regardless of me having the same or similar phones used in their testing.
19 20
