webreaper
- Sep 15, 2016
So, with all the fuss about the iPhone 7 3.5mm jack, it's piqued my interest in Bluetooth/wireless. I have a Galaxy S7, so don't need to go wireless, but hey...
I have a pair of IE80s right now, with custom sleeves, so don't want to have to change them, so wondering what my options might be to go to wireless with the existing IEMs. After a bit of googling, these turned up on AliExpress:
https://www.aliexpress.com/store/product/New-Custom-Made-Wireless-Bluetooth-4-1-Headphones-Upgrade-Cable-Suitable-For-IE8-IE80-SE215-535/1825606_32518253149.html
But they look kinda cheap, with a short battery life and apparently terrible sound quality (although that's probably not bad, considering the price!).
Another alternative would be something like this:
https://www.westone.com/store/music/index.php/accessories/bluetooth-cable.html
But obviously that's a no-go with the IE80s, as they don't have an MMCX connection. So the question is, are there any other options? I guess it boils down to three possibilities:
1. Find some existing BT/wireless cables compatible with the IE80s - but my Google-Fu clearly isn't yielding results.
2. Find a Sennheiser IE80 => MMCX adapter, and then use the Wetstone bluetooth cable.
3. Get the wetstone BT cable, and cut the ends off and have somebody who knows how to make cables fit some IE80-compatible connectors.
Any other thoughts or ideas? For #3 above, anyone know a company/supplier who could do this?
(posted in this forum, rather than the IEM one, because I'm a new member on Head-Fi - although I've been lurking for years)
