I am really interested to this pair of headphones (bt 4.0, nfc, aptX)
But, 8 speakers, seriously? i doubt if it will damage my hearing.
What kind of devices do you connect to these headphones? pc, phone etc.?
Does aptX really work to deliver high quality streaming sound?
anyone try the nfc?
If this is still a relevant question (have not visited this thread in a while) I'll sum it up thusly after a couple months use:
They can be loud, which is a plus compared to every other BT set I've owned. They can quite literally function as portable speakers given a decent source...I put them on my nightstand and let podcasts (bt from my pc) play as I fall asleep and and can hear them fine a couple feet away. Damage to your hearing certainly seems conceivable if you blast them into your ear holes all day.
They sound pretty good imho, and I for one like the equalizer presets. From a fairly neutral sound, to muted lows, to a emphasis on lows with a nice separation (which I think most people would use), to a 'v' at the highs and lows (which I don't personally like as it makes the highs pretty tinny), to a more pseudo open-back sound (what some call a '3D' setting now-a-days)...not in that switching order.
I use them on my htpcs and phone (S3). No complaints from people about call quality in the later regard, and I've asked a few people (whom couldn't tell). Granted, it is fairly quiet in my house. NFC works fine if you find it useful. I personally like that they indeed can be paired to both a pc and phone at the same time...I did not know that was a feature of this set when I bought it.
As for apt-x, I am still not convinced it is working correctly with the stock firmware, as least on PC. I have the old, cheap creative wp-350s and there is a pop-up that apt-x is working every time they are paired to a pc (from the CSR Harmony drivers). These do not. When I used the default windows 8(.1) drivers for the adapter I imagine most are using (azio btd-400, made by realtek) even after they 'windows updated' to those dated July 2013 (newer than Harmony by a long shot) and made by realtek, I was having issues with the headset getting disconnected (dropped randomly). It sucks because the sound seemed different, if not better, with these drivers, and apt-x probably was working. Occasionally though I was given a pop-up from windows saying something to the effect there were problems with 'audio enhancements', asking if I wanted to disable them. I settled on going back to Harmony and not knowing what is going on...at least it works, and they still sound good.
While there is supposedly an equalizer and firmware upgrade downloadable from their site, it's completely borked. Sure, you can connect the phones and go into the CSR bluesuite software and mess with a bunch of stuff by clicking on a diagram, and in theory save the settings and program them, but in no way is it user friendly (even to get that far). The instructions in one of the files you can download explain in broken Chinglish the firmware can be updated with a file included...which isn't included. Many have tried to reach out to Bluedio and they have been unresponsive.
So, all in all...Worth their price (~$100)?
Absolutely. The feature set, the underlying hardware (both the drivers and csr chip) are unmatched at this price. That said, there are certainly issues (which seem fixable but likely won't be). I think a lot of people will like them if they try them. It's a step up from most everything else I've seen in the price range (especially for volume and bass), and a lot less intimidating than other sets springing up in the $300 range from Sony, Philips, and Creative. I see myself upgrading to one of those sets at some point when they are all reviewed and there is a consensus. Until then, I'm quite happy with this purchase, even if a little annoyed.
