BattleBrat
Previously known as Blasto_Brandino.
- Nov 20, 2006
For $30 I CANT go wrong
@baskingshark looking forward to reviewing my own Mini when it arrives. Btw, I no ice up u refer to technicalities in your reviews. When you mention technicalities what aspects are you referring to?
Not sure what you think of foams, but I had fit issues with the BL03, and someone a few pages ago suggested the NewBee foams:Hi, after some change (cable and reversed tip) i get pretty good sound with the Blon 03, now it's the seal i'll need to get better, i have better sound on right ear then left, but if i press more the left iem i get good sound on both side, i may have a different size of ear.. so molded tip can be a solution ?
Which model would you recomend ? again a price how reasonable compare to blon 03
Thx
And here:Blon BL-A8 is now available for $88 in a banned store.
What about real molded tips ? that can work with Blon 3 ?I have had the same problem, it was really frustrating. I have tried all the tips I have, then I've bought and tried all of the recommended ones like Sedna, KZ,F-audio tips and the only tips that sorta worked for me were some old double flanged that I have.Then the SpinFit CP145 came and gave me the perfect fit. No issues any more, they work super with the 03 for me. I like them so much, that I used them on my Fiio FH3 as well. You can give them a try.
I keep hearing good stuff about the Blon 3, but I'm worried about one thing - I listen to a lot of Symphonic Metal (Epica, Nightwish etc), and because there's a lot of female-front high vocals in those, my ears get shredded with the highs. Everything is just too bright and painful. Blon3 mentioned to have a tamer highs, and I was wondering if anyone had experience with this kind of music (source is a mobile phone with no amp).
That's good to hear. I don't have much experience with IEM, but my previous Budget headphones, MEE M6, were really hurting my ears listening to energetic music. I was able to bring it down by EQing into Harman, but I really want fun V shaped Headphones - Hopefully the BLON are just that.
Any specific tips that are recommended the BL03? The MEE-M6 came with Comply, but while comfortable in-ear, I didn't like the process of putting them on. I was decided to go on Silicon tips this time around, I seen SpinFit CP145 being mentioned.
