Blon in ear monitors impressions thread
Mar 31, 2021 at 2:36 PM Post #5,432 of 6,081
Tonymac136
Uk
hi, i just buy bl05s, im newb in audio.
should i buy DAC for my iem?
i aldy survey DAC like : audirect beam 2se, hiby FC3, ibasso dc03, shanling UA1.
which one i should buy? please help me..
thanks..
Blon IEMs do tend to sound better on the end of a small amount of amplification. I've not tried any of the ones you've mentioned but the little ES100 does the job nicely for me when i'm not using my Fiio X5 DAP.
Mar 31, 2021 at 3:03 PM Post #5,433 of 6,081
Jet Black
Manila
thanks..
Almost all of those would improve your sound signature. But I personally only have tried ibasso dc03 and it really made my blon bl-01 sound great. It's also I think the smallest of all dacs in that list that's why I also preferred it so as to be very easy to carry during travels.
Mar 31, 2021 at 3:12 PM Post #5,434 of 6,081
RikudouGoku
Member of the Trade: Earbud Maker
Sweden
thanks..
Are you going to get more iems in the future? Or are you done with only the 05s?
If you want to upgrade in the future, consider these dac/amps:
Tempotec Sonata HD pro
E1DA 9038
Qudelix 5k
Ifi Hip-dac
if not, just enjoy what you have.
Apr 1, 2021 at 9:31 AM Post #5,435 of 6,081
unifutomaki
SG
thanks..
You should try the IEM with your existing gear first, then decide if you need to get a DAC. FWIW even the Apple dongle is a completely serviceable solution.
Apr 1, 2021 at 10:51 AM Post #5,436 of 6,081
sunsun89
Indonesia
Thx. I will consider es100.
Actually i listen music just from RoG phone 2.
Yeah i agree with u, thats why i want to buy Portable DAC.
E1DA 9038
Qudelix 5k
Ifi Hip-dac
Thx for the feedback. I will consider your suggestion.
For Now i want to use my blon bl05s till broken.. then i will upgrade it.. lol
Yeah i aldy try it with PC and android phone ROG 2 for about 3 weeks. And i just curious if i use DAC, it will improve my iem or not..
PS. sorry for my bad english.
Apr 4, 2021 at 8:00 AM Post #5,437 of 6,081
Jet Black
Manila
Blontastic
Apr 4, 2021 at 8:52 AM Post #5,438 of 6,081
Jitu13
Tuscaloosa, Alabama, USA
Apr 4, 2021 at 9:26 AM Post #5,440 of 6,081
Jet Black
Manila
The one with the wire attached is the Blon BL01.
Yeah the only one new was bl-03 as many of you here says it's superior to the bl-01 (that i personally doubt). Im gonna test it more as it needs a kinda burn in, (tho i really don't believe in it). So far they have similar sound signature being bl01 darker and faster bass
Apr 4, 2021 at 9:28 AM Post #5,441 of 6,081
TheVortex
U.K
I personally would not say it's better but a little different.
Apr 4, 2021 at 9:44 AM Post #5,442 of 6,081
baskingshark
Jabberwock Island
My 2 cents is that the BL-01 is brighter than the BL-03 and it is a marginal upgrade in technicalities and bass speed/tightness over the BL-03. Both have bad fit for me, but the BL-03 more so. BL-01 however, needs more amping than the BL-03.
Apr 4, 2021 at 10:34 AM Post #5,443 of 6,081
Sebulr
Leicester, UK
The only difference I have found with using a cheap amp is that the 01 drives better at low volumes its like a loudness switch for the bass and treble. Sounds a lot better at about 75db. The 03 the bass decay is a little bit faster with an amp. Depends what I'm listening to, but if I'm listening to the cure, I prefer the bass of the 03, as it has a longer decay. Also they have been known to use some flange effects.
For general listening, I prefer the 01.
