Sebulr
The sound of the bl-05 confuses me too. I think it's the lack of slam on drums. It is slightly better with taped nozzles and foams. Or a lot of eq. Like @Slater said it sounds completely different.
I really like the sound of the Blon-T1 (?) which is discontinued. They do have a new T3 model out now. The T3 looks like an earbud but is an iem.
Why little talk about the T3?
Are all Blons worth buying? I'll pass on the 05's due to price. How are the 03S?
The purple 03 has a different designation...There is no 03S. There’s an 03, an 05, and an 05S. No 03S.
I think someone from Audioreviews could show me their version? But here is it courtesy of Banbeucmas' graph comparison tool. All the BLON IEM in current production.. except for the BL-T3... Or I think you can still buy it anyway.
... I wonder what I can recommend to the rest of my family should they'd be interested in one of these. I know my sister had her mind blown by my BL-03 before she shipped it to me.
That being said, besides her, I only know a cousin who regularly uses IEMs... usually whatever IEM his new cellphone includes.
Do I wanna recommend her the BL-05s assuming she doesn't mind stretching the budget and the BL-01 to my cousin as a step above his freebies?
As for drivability I reckon my cousin's cellphone doesn't have a jack, so either going wireless or using a USB-C dongle would be a must anyway.
I'd also like to try a TinHiFi T2 but I'm too broke to even buy that currently.
Some folks do a mesh mod to make it sound brighter and better in technicalities
Don't forget about the 01... I just read someone say that it's the best budget iem of 2020.
Your post made me weary of buying any Blon... I will check out the earbud iem Blon T3 though.I have all these BLONs and I think the graphs above do correspond to what I'm hearing.
BLON BL-05S is probably the most technical and most balanced of the lot. BLON BL-05S is meh from a smartphone, amping lets it scale quite a lot. It is also the most pricey BLON IEM of the above in your list, so something to take into consideration. Though one can argue that the BLON BL-03 and BL-01 may need aftermarket eartips and cables due to the poor fit for some, so adding these in may make it cost the same (if not more) than the BL-05S. BL-05S is quite okay in fit OOTB, but I would think quite a few users may not wanna use it cause of the garish green colour. At least for me, the BLON BL-05S fixes the bass bloat of the BL-03 and the shoutiness of the BL-05 (non S). It has the best soundstage, details, imaging and instrumentation of the BLON IEMs.
BLON BL-05 (non S) is not talked about much now, it has been superceded by the BL-05S. The BL-05 (non S) is too shouty in the upper mids region and reviews about it are lukewarm at best. Fit is good, and bass is tight, but unless u EQ or do micropore mods, I wouldn't recommend it.
The BLON BL-03 has great timbre and tonality, but fit is an issue as above. Plus it isn't the best in technicalities and the midbass has bad bloat. But it is a unique classic set that opened our eyes to what a sub $30 USD CHIFI can do. Some folks do a mesh mod to make it sound brighter and better in technicalities. Very good price to performance ratio.
BLON BL-01 is a marginal upgrade over the BL-03, it has a faster and tighter bass, slightly better technicalities (but still not the best in this area). BLON BL-01 may need aftermarket tips too for fit issues. BLON BL-01 isn't as warm or analoguish sounding as the BL-03. Amping is very necessary in the BLON BL-01 to sound good. It is the cheapest of these BLONs discussed here, so very good price to performance ratio, though it ain't a giant killer for me due it not being the best in technicalities. A good set to chill back and relax.
For recommending the above BLONs to newcomers, I personally won't recommend the BL-03 due to fit issues, neither would I recommend the BL-01 cause it needs amping. The BL-05 (non S) is too shouty and fatiguing, and perhaps the BL-05S is probably the only one I would recommend, assuming they ain't put off
