Block DC Offset at amp. output.
Mar 14, 2006 at 2:33 PM Thread Starter Post #1 of 26
]|[ GorE
I am planning on replacing the JRC4556 on my sound card with the AD8397.And since the AD8397 is said to have some output dc offset,i was wondering if attaching a capacitor at the output of the opamp would work.
And what negative impact would it have on the sound ?
Mar 14, 2006 at 2:43 PM Post #2 of 26
civilmonkey
I'm pretty sure you can do that, but from what I've learned so far, basically anything in your signal path will degrade the sound. It's just a matter of how much.
For caps in the signal path, polypropylene, PPS and polyester caps are best (in that order).
Check out http://www.tangentsoft.net/audio/input-cap.html
For more information.
EDIT: I think there was a thread on this if you search these forums. Keep in mind I'm brand new to DIY audio, and one thing I've learned here is take advice with a grain of salt.
Good luck!
Mar 14, 2006 at 3:00 PM Post #3 of 26
jar
Be aware that the 8397 is quite finicky. It probably won't just drop into an existing circuit and work properly. Take a look at the MINT v2.0 and Mini^3 threads on that other forum.
Mar 14, 2006 at 3:17 PM Post #4 of 26
rickcr42
Are YOU talkin' to me?
You can go that route and would even be a good way if you had to use the chip in a single polarity power supply but the cap will be a BIG one so must be the best quality you can get.
Capacitors in the signal path are audible but that does not mean some very good sounding cap coupled amps can not be made (Szekeres for one,almost all SE Triode amps,even some Class-A speaker amps).
Look at around 470uf if driving low Z cans,220uf for higher Z headphones and around 10uf for line level
Mar 14, 2006 at 4:09 PM Post #5 of 26
n_maher
Resistorous Conflagorous
My first question would be why the 8397? Are you hoping to not have to use the soundcard with an amp? In my opinion you'd be much better of going with a more stable opamp (echoing jar's comment) since it's surface mount application and it'd be nice if you could just drop the chip in and be done. Maybe the 2134 or 2227 would be a better choice?
Also, what soundcard is this? Is it really worth modding it or would you be better of buying a decent inexpesive one like the AV710 and using the line out to an external amp? I find my 710 run through my PIMETA to be quite nice given the cost of each.
Nate
Mar 14, 2006 at 4:46 PM Post #6 of 26
ericj
Since the 4556 and the 8397 are both bipolar amps, they should have similar output offset.
Unless your 8397 starts oscillating, and it probably will. It is NOT suited to drop-in replacement uses.
Mar 14, 2006 at 5:52 PM Post #7 of 26
]|[ GorE
the card is a modded Audigy 1 24bit Value.Why do you think the 8397 would start oscillating ? Coz the modded card has a 220uF cap and a 0.1uF bypass cap for V+ and V- (meant for the opamp).
Mar 14, 2006 at 6:29 PM Post #8 of 26
guzzler
The opamp on the sound card will likely be being used a buffer, ie, a gain of 1. All opamps have something called their "gain-bandwidth" product, which means their bandwidth drops with increasing gain. The AD8397 is extremely fast, over 100MHz, while the JRC is in the 10MHz region (check the datasheets!). This means the 8397 will respond to any stray capacitance/inductance at its input pins, and possibly drive it into oscillation. As has been mentioned, an opamp with a similar bandwidth is a more appropriate choice
Mar 14, 2006 at 6:41 PM Post #9 of 26
rickcr42
or just slow it down with loop compensation and an input shunt cap.Not a bad idea for most audio use opamp devices which are quite content (and will act less badly) at 1-2mhz and slew rates in the 20's.
Many "bright" sounding op-amps are actually oscillating or ringing in the mhz range with the artifacts being audible much lower which reinforces the upper octaves.Some call this detailed sound but would be shocked to see the reality of it on a scope trace
To be honest I could live with dead flat and well behaved from 30hz to 15khz over ultrasonic with artifacts any day and most others could also if they never knew there was a rolloff at the ends.It is more the knowing than the listening and why so many get hung up on specs over performance
Mar 14, 2006 at 8:16 PM Post #10 of 26
MisterX
As someone that has been there and done that (except I used AD8620s) I would suggest that you not waste your time.
The stock opamps actually do a pretty decent job of masking the horrible top end that the Philips UDA1328 6 channel DAC featured.
Mar 14, 2006 at 9:26 PM Post #11 of 26
rickcr42
that statement is way overblown.There are many opamps being used here every day that are more prone to go into oscillation the LM6171 being one and I see that stops no one from using it.They just pay closer attention is all.
The AD8397 is what it is.A bipolar input opamp no worse than any other bipolar opamps that gets GOBS of output current while still remaining battery freindly and if you follow simple opamp housekeeping techniques (see ADI library) is no worse than any other high speed opamp.
Proper layout,loop compensation,and a proper power source and no more of a "chore" than any other opamp.
The above statement is a scare tactic for whatever reason.Read the app. notes and do a proper layout and you are fine.If you need to do a SMD/DIP adapter look to the AD825 plug in modules or AD8065 modules available from various mod services for hints on how.
No scary monster,just an opamp and a slow one when directly compared with most modern opamps in regular use here for audio
Mar 14, 2006 at 10:02 PM Post #12 of 26
rickcr42
For "clarity folks.A couple of commonly used opamps and their speeds :
OPA637
Bandwidth 80MmHz,
Slew Rate 135V/uS
http://focus.ti.com/docs/prod/folders/print/opa627.html
OPA2134
Bandwidth 8mhz
Slew Rate 20V/uS
http://focus.ti.com/docs/prod/folder...t/opa2134.html
OPA604
Bandwidth 20mhz
Slew Rate 25V/uS
http://focus.ti.com/docs/prod/folders/print/opa604.html
LM6171/2
bandwidth 100 mHz
Slew Rate 3600V/uS
http://www.national.com/pf/LM/LM6171.html
AD825
Bandwidth 46mHz
Slew Rate 140V/uS
http://www.analog.com/en/prod/0,,AD825,00.html
AD8620
Bandwidth 25 mHz
Slew Rate 50V/uS
http://www.analog.com/en/prod/0%2C28...8620%2C00.html
AD8065
Bandwidth 145 mHz
Slew Rate 180V/uS
http://www.analog.com/en/prod/0,,759_786_AD8065,00.html
AD8397
Bandwidth 69 mHz
Slew Rate 53V/uS
http://www.analog.com/en/prod/0,2877,AD8397,00.html
looks pretty much "middle of the pack" to me.......
Mar 15, 2006 at 8:34 AM Post #13 of 26
fewtch
This thread really makes me ponder if the opamps we commonly use around here are not only insane overkill, but actually counterproductive in some ways. My CD player uses good ol' NE5532s which not only sound pretty good to my ears, but are more logical for audio use than some of these others that would fit better in radar guns and space weaponry
Mar 15, 2006 at 3:06 PM Post #15 of 26
NeilR
I thought the whole point of this forum was to apply insane overkill to what otherwise would be $30 consumer electronics devices
