BIT-PERFECT Audio DAC
Jun 23, 2009 at 8:42 PM Thread Starter Post #1 of 11
hortoholic
Hello, I have came across the BIT-PERFECT DAC and I was asking if anyone who owns this if it's any good. I want to use this for my Grados SR60's. Any ideas or recommendations would be great. If you know of any for a similar price (less than $100) that would also be great.
Thank you greatly,
hortoholic
Jun 23, 2009 at 8:57 PM Post #2 of 11
That really doesn't tell us anything. Do you have a link to this DAC? DACs are "passive" in terms of what they process, you send a digital stream (whether it be bit perfect or not) and the DAC converts it into an analog stream. There is no such thing as a "bit perfect" DAC (or not - well, unless you upsample).
Jun 23, 2009 at 9:12 PM Post #3 of 11
Jun 23, 2009 at 9:22 PM Post #4 of 11
seems like a burr brown pcm chip, not all that diff from the gamma1, bantam and similar.
the only thing bit-perfect is that this dac wont' FORCE a resample to 48k, for example.
but if you use digital volume control at the source (pc) then you WILL lose bits (in res) due to digital atten.
if you leave the host (pc) vol control at 100% then its bit perfect but so are most others, too!
