Big difference between Stax SRM-252s and 323s?
post-8860606
Thread Starter
Post #1 of 6
lovan
Hi
I'm thinking of buying myself a pair of Stax SR-009. I think I will try to build a KGSS or BHSE but in the meantime I want an amplifier.
I'm thinking of buying a 252 because it's small and portable.
I'm curious if this amplifier is a bad match for the 009s? Has anybody compared the 252 and the 323?
Thank you for your input!
Niclas
post-9055346
Post #2 of 6
borizm
Gdańsk, Poland
Gdańsk, Poland
Stax SRM-252 is similar in design to [I've heard] great SRM-323 but SRM-252 is full of mistakes (miscalculations), tradeoffs and savings, and when we talk about "the sound", SRM-252A is just a piece of crap(!!!) [sorry, but it's true as the sky is blue, comparing even to first solid and simple SRM-1 built in 1979], and I suppose SRM-252S is not a much better.
At http://www.head-fi.org/t/546221/srm252mod is a discussion what can be done to fix the sound of SRM-252A and maybe made our own SRM-252U (Ultimate) which will be as good as SRM-323S without having such big enclosure and without producing so much heat (small box), and of course still at an affordable price. Almost impossible, but worth trying.
post-13367572
Post #3 of 6
Yngve
Borizm, you cal the srm 252s, crap. And you have not heard it's sound....
I have bought the 252s and Sr l500, and this setup plays so nice.
What i now like to know, is how much soundquality can i gain, in uppgrading to a more expensive driver ?
And is the sound of the tubedrivers, much better than solidstate ?
If there is one out there who has compeard the 252s, with an other driver, please tell us the difference in sound ?
Happy new Staxovner.
post-13368184
Post #4 of 6
Petyot
Montreal, Canada
Montreal, Canada
I have had my SRM-717/SR-007mk1 from 2006 to 2017. When I started to venture in the Stax sound I bought a few systems that I had at the same time. So, at a moment I had the SR-007 and SR-404 for the headphones and the SRM-717, SR-006t, SRM-212 and SRM-Xh for the amps.
I tried both the SR-007 and the SR-404 on every amp and, FOR MY EARS, there was almost no differences between the four amps... The differences were more between the SR-007 and the SR-404. But each headphones sounded pretty much the same for me on each amp...
In the end, because money was not a problem, I kept the SRM-717 but I could have lived happily with the SRM-212...
There are really too much superlatives when describing differences between amps on audio forums... The famous : "night and day", "heard things I have never heard before"...
Anyway, to come back to the subject, chances are there will be no big differences between the SRM-252s and 323s (if any audible differences...).
post-13370136
Post #5 of 6
axle_69
  Hi
Niclas
The SR-009 is demanding, how much time will you take to build or buy an amplifier that matches the SR-009? You may be better with a 5100 system (353X + L500) or with a used 323s and a lambda (much easier to drive than the omegas) while you build an amplifier and then sell it and buy the SR-009.
post-13370221
Post #6 of 6
Yngve
Thank you Petyot.
Nice to hear your review on the drivers.  I live in a small city in the middle of Norway, a long way from any shop selling Stax.
So listen before buying, is often difficult. My Stax gear is brand new, so i have only used it for a few hours.
Since most audio gear need some use, before it gives its best sound, i need some more break-in time, before i make up my mind on any upgrade.
Yesterday i got my new Gustard x20pro DAC, and that made a big step up in sound, from the dac in my Cambridge audio bluray, and my Henry Audio USB DAC.
I was thinking on buying a tube DAC, for my Stax, but now, after listening to the Gustard, i am happy i went with it.
