Month and a half later, and I'm still in love with my Xelentos!I just traded my SE846's for the Xelento, and I am very, very impressed! These sound excellent (pun intended).
Beyerdynamic Xelento!
- Thread starter thatonenoob
ColinMacLaren
- Jan 29, 2016
I contacted Beyer concerning the availability of the bluetooth module. They replied that they don't know yet when it is going to be released - which means that they are definitely going to release it.
Snowball0906
Hi, may I know what is the difference between first generation and second generation of Xelento?
https://support.beyerdynamic.com/hc...n-sound-between-the-different-Xelento-models-Hi, may I know what is the difference between first generation and second generation of Xelento?
the only difference i know of is wired and wireless. in that case its just a cable - swap
Snowball0906
Hey man, thanks. How about it’s build quality? I saw that there’s some fitting issues on third party cable?
Well, to be honest, when I traded my 846's for them, i attached my ALO litz cable, it felt a little funny, but its been almost 2 months, and I roll between balanced and unbalanced Litz, and I've never had a problem, they sound great. I'm constantly amazed by these things...Hey man, thanks. How about it’s build quality? I saw that there’s some fitting issues on third party cable?
kms108
- Jan 27, 2012
the difference is the serial number plate.Hi, may I know what is the difference between first generation and second generation of Xelento?
kms108
- Jan 27, 2012
I'm using the final audio cable, best fit, nice design, but rather expensive.Hey man, thanks. How about it’s build quality? I saw that there’s some fitting issues on third party cable?
Chessblitzer2017
The pure silver litz added some engagement but couldn't compete ergonomics wise with the stock. Kinda wanna try the linum superbax.
Well, normaly for these I use the balanced cable to add a little precision to the dynamic driver, and I always use Comply foam tips Ts-500, but the last two days I have been using silicone tips that came with my Andromeda's, and it's a refreshing change!
kms108
- Jan 27, 2012
My Final Audio has been terminated with a OFC Pentaconn 4.4mm balanced plug.Well, normaly for these I use the balanced cable to add a little precision to the dynamic driver, and I always use Comply foam tips Ts-500, but the last two days I have been using silicone tips that came with my Andromeda's, and it's a refreshing change!
Victorfabius
Question for you all:
Is the Xelento Wireless worth the cost? I'm thinking about it as a successor to the Flares Gold. But I'd like to get the opinions of people here. I did the same on the Flares Gold and have not regretted it.
Also, if you don't think it's worth the MSRP of US $1199, where would you think its value lay?
Thanks!
Thanks!
kms108
- Jan 27, 2012
You will only get the best SQ with cables, wireless is only for convenience.Question for you all:
Thanks!
I put it's sound signature right next to AndromedaSS, different sound-sgs, but same level of performance, they compliment each other well!Question for you all:
Thanks!
Victorfabius
Yep. I'm aware. However, the Flares Gold has a 5 hour or so charge on their bluetooth adapter, and it only gets AptX. Thinking this is a nice convenience upgrade, but most listening will be through cable.
