Chessblitzer2017
MwaHahAhAHA Always an enjoyment too see Mr csglinux's input never fails
Beyond a few hundred dollars, we're talking mainly about FR preferences. There's little to no correlation between price and SQ at any price level accoridng to Sean Olive's research. I've heard most TOTL IEMs and the only ones I'd say were marginally ahead of the Xelentos are the KSE1500/1200. There's still no blowing away there
Thanks for your recommends! I will remember them whenever I get around to purchase a DAP.Xelento with QP2R is fabulous, out of balanced. I would say that the balanced is definitely better, but not by margins seen on some other DAPs(like KANN), as compared to the QP2R. The Effect Audio Ares II+ balanced is a fantastic pairing for the Xelento. The AK TiE balanced cables are decent, while maintaining the ergonomics of the original cable.
This would be off topic here, but nevertheless: Are you happy with the UI of the QP2R? Does it work easily to play entire albums from the directory view? Does the wheel work well?Xelento with QP2R is fabulous, out of balanced. I would say that the balanced is definitely better, but not by margins seen on some other DAPs(like KANN), as compared to the QP2R. The Effect Audio Ares II+ balanced is a fantastic pairing for the Xelento. The AK TiE balanced cables are decent, while maintaining the ergonomics of the original cable.
Your understanding of what I said is correct. Even with the small improvement, I always tend to listen out of the balanced.Thanks for your recommends! I will remember them whenever I get around to purchase a DAP.
Just to reconfirm my understanding of your wording: Xelento balanced out of QP2R is better by some amount, while it‘s better by a large amount out of other DAPs like KANN. Sorry for asking, my limitations.
Thanks for your open words. I was afraid that all I read on the QP2R thread here at head-fi does indeed boil down to just that, although people there - of course - tend to be not as frank as ”just sucks“... I guess the QP2R is a puristic thing, while the iBasso DX220 is more of a high-end toy. Well, I tend to be a purist, too, but I also like a bit of toying. Luckily, in favor of the QP2R, I think to have a good folder structure in my audio library.The UI sucks. No other way around it. I am able to use it as I listen via Folder browsing and a good structure helps to manage the navigation better. The wheel tends to suck really on startup, and once the DAP warms up, it seems to move smoother.
We can take further via PM if you want as it pertains to Qp2r, but any irritation, disappears when music starts. Please ping me via PM, if I can assist you further.Thanks for your open words. I was afraid that all I read on the QP2R thread here at head-fi does indeed boil down to just that, although people there - of course - tend to be not as frank as ”just sucks“... I guess the QP2R is a puristic thing, while the iBasso DX220 is more of a high-end toy. Well, I tend to be a purist, too, but I also like a bit of toying. Luckily, in favor of the QP2R, I think to have a good folder structure in my audio library.
I purchased my Xelento about 5 months ago and have had driver flex in both sides from the beginning. Though I don't use them frequently (due to having many IEMs), the driver flex has gotten much worse. I used them this morning while out for a walk, and the driver flex noise occurs on the left side if I open my mouth or move my jaw - and between tracks, I can even hear it with each step while walking. It seems the slightest change in ear pressure causes it (and obviously it loudly occurs when I first put them in, or press on them while in my ears). At this point, they're unusable because of how pervasive the problem is.
For those who have gotten replacements from Beyer, did the driver flex problem come back? How easy is the replacement process?
I wonder if this is a known defect by Beyerdynamic, and if certain batches have the issue (and maybe they've fixed the issue in newer models)?
Replacement process was super easy—just send Beyer support an email and explain what's going on. In my experience (and in others') they're super responsive and fast. It's been a few months since mine were replaced with a new set, and I have not noticed any flex since then. I noticed flex in the original set every time I put them in regardless of how carefully I did it.I purchased my Xelento about 5 months ago and have had driver flex in both sides from the beginning. For those who have gotten replacements from Beyer, did the driver flex problem come back? How easy is the replacement process?
I suspect this is a constant issue with the extremely small manufacturing tolerances in this IEM. It sounds like it's occurred for some folks since the Xelento first came out, and as far as I've experienced, it can still be present with the new Xelento Wireless. That said, between its excellent ergonomics, sound, and support from Beyer, it's a great IEM to take the plunge on.I wonder if this is a known defect by Beyerdynamic, and if certain batches have the issue (and maybe they've fixed the issue in newer models)?
I had my Xelentos for all of 4 days when I had to send them in for replacement. From the first insertion I had driver flex on both sides and on the left, the sound would hust cut out due to it. On day 4 The sound left and never came back.... that was 2 weeks ago. They were very quick in issuing an RMA - A week in shipping to them, 10 days in shipping back to me, I should have a new set here Tuesday next week and will post if the new set direct from manufacturer is any different..Replacement process was super easy—just send Beyer support an email and explain what's going on. In my experience (and in others') they're super responsive and fast. It's been a few months since mine were replaced with a new set, and I have not noticed any flex since then. I noticed flex in the original set every time I put them in regardless of how carefully I did it.
