BassHead808
- Dec 25, 2016
So i got these a week ago on amazon and finally started getting to use them since they where a gift. I am using the 80ohm version and i also have a Fiio A3 amp which definitely makes them louder. I have been listening to these for a bit now, a few hours and they sound good, until i went here (http://www.audiocheck.net/soundtests_headphones.php) to test them and I noticed that on the low ends of the dynamic range and quality these headphones have the rattling noise. Not sure if Iam over powering them or what because if i run the test on my mac without the amp I do not get the rattle. I listen to dubstep, bass music, hip-hop so low end bass is something I love. Dont know if that will fix after I put some hours on them or not, just needing to know if I should go with something else before the return date passes. Thanks!
