Beyerdynamic DT 770 Pro - Limited Edition, 32 Ohms
Mar 15, 2014 at 8:22 AM Post #571 of 679
Oh no no, my 32ohms are not LEs.
Beyer decided that the praise of the original LEs made it worth launching a regular 32ohm version called "The Studio Legend".
As of now it appears that LE and Studio Legends have two different parts (the pads, and a plastic thing inside the cups which the LEs are missing - see previous posts)
Sound signature appears to be between LEs and SLs according to Golden Ears.
I'll see if I can get the leather T5p pads. Is the fit same? same diameter, etc?
Cheers,
Yes, the same dimensions.  Although it doesn't provide the same level of seal.
Mar 15, 2014 at 7:49 PM Post #576 of 679
Is sewing skill a requirement to attach the Fischer pads onto the 770's cups?
No sewing required.  They go on just as easy or easier than the beyers.  Not difficult to get them on.  I have the Jaycar (digitech) verison of the FA-003.  Just assuming that the pleather pads are the same.  The pads are much softer than stock beyer pleathers.
Mar 15, 2014 at 8:24 PM Post #577 of 679
Thanks.  Care to provide the URL from which you bought your pads?
Mar 15, 2014 at 8:43 PM Post #578 of 679
I own Jaycar version of the Fisher fa-003, so I used those pads.  I can't find any Jaycar replacements, but I did find these on amazon:
http://www.amazon.com/NVX-XRE100S-Replacement-ComfortMax-Headphones/dp/B00EFD7TQQ/ref=sr_1_3?s=electronics&ie=UTF8&qid=1394930290&sr=1-3&keywords=nvx+xpt100
Same pads from another FA-003 clone.
Mar 15, 2014 at 8:47 PM Post #579 of 679
Thanks!  And these pads fit the cups of the DT770 LE?
Mar 15, 2014 at 8:47 PM Post #580 of 679
Hi all,
I sold my old DT770 Pro 80 and bought the 32 ohms Limited Edition.  I found this to be smoother but the bass reverberations left me wanting to mod it.  So here's what I did so far:
- Replaced the stock pads with the pads from T5p.
   I did this to lessen the reverb or shorten the bass decay and add a bit more air to the treble.  And it did effect in those two desired qualities.
- Punched three holes in the middle of the foams that cover the drivers.
   I did this to bring forward the slight-recessed mids of the 770 LE.
The stock pads of the Limited Edition 770:
The new pad:
The mod on the driver covers:
I tried the velours from my T1 but the bass dissipated down to an unsatisfactory level.
Did you try the 32 ohm with velour pads?
Mar 15, 2014 at 8:54 PM Post #583 of 679
Try the stock dt770 velour pads on the 32 ohm version.. It shounds awesome.
Sadly, I no longer have those.   But I like the seal of pleathers.  So I think I'll stick to the pleather or leather pads for now.
It kinda provided a different flavor for my musical enjoyment.  I have the HD800 and T1 and both of them are opened-backs.  Even my DT-1350 is opened.
