Beyerdynamic DT 1990 PRO - Beyer's open-back mastering headphone
Discussion in 'Headphones (full-size)' started by xero1, Jul 19, 2016.
136 137 138 139 140 141 142 143 144 145
147 148 149 150 151 152 153 154 155 156
  1. ohsigmachi
    Wow, that looks amazing, I bet the sound is crazy!
  2. richie60
    I have only tried the stock GE6080 that came with the Crack and also the Russian Winged C Svetlana 6A7SG which I wasn't too keen on.
    I like the Thomson so much that I'll be buying another one soon to stock up on. It's a nice quiet clean transparent sounding tube that suits both the Sennheiser HD600 and the DT1990 for me.
  3. Scutey
    The sound is wonderful, the warm-ish sound of the Elise and the bright-ish sound of the 1990's works so well, and both scale up very well too, with better tubes, at the mo I'm using british military CV1052 tubes, which give an incredible depth of sound, warm, yet transparent with lots of detail and energy, 3d imaging from this combo is the best from any, headphone/amp set up I've ever used, and I've had plenty of them!.
    cardeli22 likes this.
  4. paul2qute
    I love the beyerdynamic Dt 1990 but it struggles with a decent amp, it's begging for mercy
    Put my Mr speakers Aeon on and that struggles but not so much as the beyerdynamic Dt 1990,wimps of the headphone world
    I don't wanna be limited to the headphone I choose
    Any headphones out there with balls ?
  5. kman1211
    From currently-made Beyers, the T1.2 and the Amiron Home scale up better than the DT 1990, the better the system the bigger the gap in my experience. It became apparent to me the DT 1990 is tuned for professional usage, tuned to sound good out of most everything but also seems to hit a brick wall in terms of scaling, the Sennheiser HD 660 S(the HD 650 is better on a higher end system than the HD 660 S) is similar in this aspect. This is the reason I chose the Amiron Home and T1.2 over the DT 1990. This makes the DT 1990 great for the average system but it's not the best choice for a summit-fi systems. Honestly the T1.2, HD 800 S, some of the Focals and various other dynamics would be better choices with high end gear in terms of dynamic headphones. I am wanting to hear the MySphere 3, hopefully will be able to in the coming months. The reason my modded DT 480 is my main headphone is because it never seems to stop improving with mods and better systems, I get this uncanny feeling that it's potential is limitless, plus when driven well it's essentially impossible to distort, I haven't experienced that with any other headphone I've owned.
    Beagle and Light - Man like this.
  6. Csericks
    I use my DT 1990 with a Woo Audio WA2 - they seem made for each other!
    cardeli22 and ohsigmachi like this.
  7. grig
    Fiio A5 can drive properly the DT 1990 ?
  8. harpo1
    Easily.
  9. grig
    good to hear, that mean as well that the Topping NX4 DSD can drive them quite easily as well, hard choice now....which one....
  10. CycleMotion
    People I have problem. This headphones spoiled me... I'm looking for portable option and I tried iSine 10, SINE, V Moda M100, V Moda XS, B&W PX and I'm pretty disappointed with every of them, M100 are probably my favorite in bunch. My question is...are there any options with similar sound signature to 1990?
  11. oldmate
    A little more bass than the 1990's but in a portable should not be an issue out and about.
    Beyerdynamic T51i. The little brother.
    CycleMotion likes this.
  12. kelly200269
    The DT1770. That’s if you regard them as ‘portable’!? lol
    cardeli22 and CycleMotion like this.
  13. CycleMotion
    Acctualy that’s good choice, how are they soundwise?
  14. Luminance
    You may want to check out the Takstar Pro 82. I have the first revision with more sparky treble and longer 2.2m cable. Though the second version should be close enough. For me, the sound signature is quite similar to the DT 1990, except that mids seem to be a little more forward.
    DT 1990 Pro
    [​IMG]
    Takstar PRO 82 first revision
    [​IMG]
    Takstar PRO 82 second revision
    [​IMG]
    T51i
    [​IMG]
  15. oldmate
    They sound phenomenal. Obviously not exactly like the 1990's but highly recommended. Sensational build quality, very comfortable for on ears and heavily discounted at the moment depending on where you live.
    But as always I recommend auditioning them 1st. Guarantee you buy them!!
