Beyerdynamic DT 1990 PRO - Beyer's open-back mastering headphone
Discussion in 'Headphones (full-size)' started by xero1, Jul 19, 2016.
132 133 134 135 136 137 138 139 140 141
143 144 145 146 147 148 149 150 151 152
  1. paul2qute
    They do look sexy though the Dt 1990,a proper man's headphone oozes testosterone,I hope they sound like a BMW M4 rather than a Corsa with a drain pipe of an exhaust
  2. oldmate
    In my line of work (Cisco) I come across script kiddies all too often. I wonder what the audiophile equivalent would be?? :ksc75smile:
    bfreedma and kelly200269 like this.
  3. Scutey
    Lol don't forget to give em a good sniff as well!. As for the bass, with B pads on and my best bassy tubes in my tube amp I can get a fab bass rumble out of them.
    paul2qute likes this.
  4. paul2qute
    The drivers are exactly the same
  5. AxelCloris Administrator
    Let's please keep the discussion on-topic. Thanks everyone.
  6. paul2qute
    One more day, can't wait now
  7. Scutey
    Hope you enjoy them! :beyersmile:
  8. paul2qute
    When I had the focal Clear pro the coiled cable was a nightmare,it use to Yank the hugo 2 everywhere but hopefully my hugo TT 2 won't move
  9. Darksoul
    I've used these for close to a year and I've loved them. However, lately I've found my self wanting more on the lower end. I want more bass, without losing clarity and detail. I've played with equalizer APO extensively and the results always end in muffled sound, loss of details and an unnatural sounding bass.
    I've considered in going for a pair of dorkly looking Stax, one of the starter systems. Or going for a pair of planars, my options have been the LCD-X or LCD-2, maybe Hifiman if I can find a good deal on any of them.
    If I wanto to keep the same detail and clarity on the DT-1990 but with even more bass what should I aim for?
  10. George Taylor
    You could do what I do. I'm using the Ifi Micro IDSD Black and just turn on the bass boost if I need a little pop. Might be cheaper than buying a different set of cans, especially if you can't try them before hand.
    cardeli22 likes this.
  11. imran27
    I would highly suggest keep DT 1990 and get an amp to get that kick in the low end.
    I always had the thought of letting go of the DT 1990 for something like Sundara.
    After having tried DT 1990 with a lot of amps, I am amazed and awestruck every time to see how amazingly well this damn headphone scales up with the upgrades in the signal chain.
    Recently I tried the Cayin HA-300 with Burson Play and DT 1990(A) and I got goosebumps with every song I tried. Replacing Burson Play with Chord Hugo M Scaler (highes sampling rate) + Chord Qutest (neutral filter) was just pure bliss and eargasm.
    I am yet to find a headphone that maintains it's own characteristic sound but still has such an amazing transparency and resolution to reflect signal chain changes.
    But if you really insist on more bass, I would say LCD-X is actually a great option. It's got quite a good amount of bass while keeping the details and texture. It just doesn't have that precise placement and separation of a diffused field tuned Dynamic driver.
    cardeli22 and Essence STX like this.
  12. natto lover
    audeze has the bass but less detail (aside from lcd4 models). I'm all for stax but they're hard to recommend going into going blind, and the bass is...different.
    maybe the Auteur? not sure what your budget range is but they're pretty neutral with a slightly warm tilt. plenty of detailed treble too
  13. Darksoul
    I got a Violectric V200, they certainly brought the kick on the low end, and the FIRE on the highs wich ended up balancing each other out. Thus I'm left looking for a new pair of cans.
  14. imran27
    If you are willing to, you could try Burson Play.
    I recently found opamp configuration that reduces the harshness without loosing the details of the top-end. And there are many methods of fine tuning the sound of whatever opamp configuration you use.
    What I have right now, I am going to fine tune it to have a bit more bass and darker background.
  15. oldmate
    Little dot MkIII or Darkvoice 336SE. Then roll tubes to achieve the desired sound.
