Beyerdynamic DT 150: Bloody Brilliant!
Discussion in 'Headphones (full-size)' started by theobservatory., Oct 25, 2007.
28 29 30 31 32 33 34 35 36 37
39 40 41 42 43 44 45 46 47 48
  1. Synthax
    It is helpful to use sushi bamboo stick during puting pads on dt150, You shuold guide the plastic seal with this stick and slide around accordingly to putting pad on earcup..
    Lorspeaker likes this.
  2. tame
    What are sound differences between those pads?
  3. Tiemen
    Not much, compared to the stock pads. With both the drivers are a bit more closer to the ear.
  4. tame
    May be somebody tried Brainwavz HM5 Velour pads?
  5. Baycode
    I have both pleather and velor HM5 earpads and I couldn't put them on the DT150.
  6. Tiemen
    Just thinking, I used the old, flatter HM5 pads. Maybe the new ones are stiffer?
  7. asutaka3
    hi, guys. Just one question: DT 150 or DT 660 ?
    I've just had myself a DT660 recently. I listen to almost all kinds of music, of which classical and jazz are on top. I find the DT 660 has a very nice SQ, however the build sucks as it's mostly made of plastic.
    I like a flat headphone, which sounds accurately (don't mind the boredness anyway). Comfy is not an issue as the DT660 has strong clamp force, too. Those 2 both hurt the same I guess. I listen to music in my own room, so mobility is no biggie and I'm willing to amp my cans, had the cheap Denon PMA 520AE.
    I have two more weeks to be able to swap the 660 for 150. Any suggestion ? Should a get the German tank or keep the 660 ?
    Thanks in advance.
  8. Headzone
    The DT660 is quite unpopular can around here.
    I'd bet DT150 is a better can overall.
  9. Lorspeaker
    ....get the DT150... your great grandson is gonna thank u.
  10. asutaka3
  11. colt1664
    Then the DT-150 is for you!
  12. Baycode
    My Chinese Velour DT150 earpads will be here in 7 days. I will inform the community about the quality/fitment and provide a link if its worth.
  13. Tiemen
    Chinese velour DT150 earpads [​IMG]
  14. Baycode
    Anyone try to mod their DT150 out there? (cable, inner cup, earpad, headband mods?)
  15. MrTechAgent
    Just to let you know..if you happen to re-cable, keep in mind that the older versions use a contact system rather than a normal solder connection.
    The 6-Pin connector as far as I know is fastened on the moulded plastic so its easily removable.
    This is a great video to learn more about the internals of the DT1XX series.
    Kaldas Research Stay updated on Kaldas Research at their sponsor page on Head-Fi.
    https://www.instagram.com/kaldasresearch/ http://kaldasresearch.com/
