Beyerdynamic DT 150: Bloody Brilliant!
post-13251488
Post #2,086 of 2,407
MayorDomino
  Bought these a few weeks back to replace my srh840's.. loving them so far, far more comfortable than my shures and a lot better soundstage, less boring sound too.
What DAC are recommended for these? Is it possible to make them sound decent with a dac around $100?
Dont waste your money just get an O2 or some other headphones.
post-13251583
Post #2,087 of 2,407
shamu144
  I recently purchased a DT150 based on all your comments (thank you for this!), and I have to say it has impressed me a lot out of the box. This is indeed a very engaging headphone, with plenty of dynamic range, which is something I am missing in the Nad viso hp50 for example.
I plan to use it mostly out of the SE output of my Audio-GD NFB28, but I was wondering if there was a balanced cable option for this headphone which does not require DIY abilities. This would allow me to use the balanced output of the NFB28 as well. I stumbled upon this 4-pin XLR cable used for the DT190 (Beyer ref part number K109.28). Do you actually know if this would be a true balanced cable compatible with the DT150 without any modifications required ?
Should I try it for the community
Thanks for sharing your thoughts !
I have been informed that this particular cable was not compatible to operate the DT150 in balanced mode... Just to let you know. They however sound fantastic as is. Switching to the Nad viso, I feel the sound loose so much of its body, and music gets somehow less engaging (I would say similar to what electrostat sound does to me). Those DT150 are really lovely !
post-13251592
Post #2,088 of 2,407
keit
  Fiio E10K will do just fine for example. The 840s are so damn heavy..i think that's their biggest flaw..
I think the biggest flaw of them is that the padding makes the drivers stay too close to your ears. They made my ears hurt from having constant physical pressure onto them. After half a year or so it got better though, maybe my ears just adjusted and went got less monkey-ears or I just stopped noticing it. In my old DT770's I had similar ear space though, which is very airy and roomy. I think the SRH840's might just have been constructed with more soft padding which made em clamp a bit too tight.
You're recommending that DAC or what? And if I don't get it I should just scrap them? I enjoy them currently but I think they might sound even better with an amp. I mean I like them better than my 44 ohm Shures even with my built in Texas Instruments OPA1652 op-amp..
post-13251702
Post #2,089 of 2,407
MayorDomino
 Nah im just saying dont mess around with Cheap DACs just Get the best amp you can afford
post-13264962
Post #2,091 of 2,407
mysticstryk
Do you need a DAC and an amp with a combined budget of $100? If that's the case, just grab a Fulla 2. The DT150 will scale up if you ever upgrade your gear down the road.
If just a DAC, the Modi 2 is about as good as it gets for under $100.
post-13268984
Post #2,092 of 2,407
amigomatt
Manchester, UK
Manchester, UK
Try and look for an HRT Microstreamer. Amazing DAC/amp for the money.
post-13273879
Post #2,093 of 2,407
MayorDomino
Wanting some DT100 pads, can someone tell if there is a difference between vinyl and soft skin?
https://www.thomann.de/gb/beyerdynamic_dt100_ohrpolster.htm
http://www.canford.co.uk/Products/54-803_BEYERDYNAMIC-SPARE-VINYL-EARPAD-For-DT100-headphone-DT108-DT109-headset-black
post-13273926
Post #2,094 of 2,407
mysticstryk
post-13274108
Post #2,098 of 2,407
Tiemen
Winschoten, The Netherlands
https://www.thomann.de/gb/beyerdynamic_dt100ohrpolstervelour.htm?sid=784130711c2ae3922a3c4f58e787be8b
