Hey there, anyone looking for a little more in-depth comparison of the ath-m50 and Beyer COP, I'll have a full comparison up within the week as soon as finals end. In the mean time, is there anything anyone would like me to address between them specifically?
Beyerdynamic Custom Ones! New Beyer headphones!
- Thread starter GL1TCH3D
SkitZ0
- Jul 6, 2011
......you have figured out my plan. Now I must kill you. Prepare to be....ANNIHILATED!!!!!!
Well I don't listen to music often enough to do permanent damage from high-volumes........at least I try not to lol. Anyway, I'm a huge fan of mid-bass "impactful" (is that the same thing? I'm still learning) cans like the DJ1, but I LOVE the look of the COP and the detachable cable, so I'm hoping that I'll get the same punch but more clarity, comfort, and less distortion at higher volumes....I'll probably need an amp either way.
Oh maybe he's planning on going Bionic when he's older! Gatta destroy his organic body b4 he can be a CYBER MAN
Isolation is pretty good. They might leak a little if you crank em up but it's definitely pretty decent. Go easy on your ears though, don't you want to enjoy music into your late years?
Also these are not purely midbass cans, they have a subbass rolloff but they're not planar, what do you expect? They go fairly low and rumble the cups easily.
jmsilva22
- Sep 6, 2012
I have the COP and the E11 and (for my taste) they didn't paired well. Couldn't crank up the volume like with my other headphones. I'm no expert, but I think it was a mistake to make this kind of headphone with only 16 Ohm / 100mW specs. They perform way better straight from the source with no amp.
SkitZ0
- Jul 6, 2011
Maybe you can help me with my distortion problem then? From what I've learned so far, distortion happens when I crank the volume louder than the amp can handle (for example, those built into an iPod or a laptop), so it begins to chip. In order to fix this, I would A. need to sound check all of my songs so they play at the same volume (about 60% effective) or B. buy an amp. But what you're saying is these headphones sound their best without one. So how would I fix my distortion problem?
- Mar 20, 2010
They were made to be driven straight off sources, so I don't understand why everyone is trying so hard to amp them. Some headphones just aren't made to be amped.
jmsilva22
- Sep 6, 2012
That is a tuff one because it depends on the source, but I only use the COP for portable. I have the Clip Zip and it can power the COP good enough without issues. For my computer and home studio I use the HD280Pro.
jmsilva22
- Sep 6, 2012
Your right. In my case I was just so used to using the E11 with all my other headphones (M80, HM3, HD280Pro) with no issues. I still think they could have done the COP with a bit higher specs. My 2 cents.
- Mar 20, 2010
The appeal of the COP for me is that I dont have to worry about loss of SQ by running it unamped. I for one HATE attaching anything to my mp3 player or phone. Less bulk. So the COP is perfect for that.
If you dont mind habing an amp attached, I'd go with something more typical, like the 770/80s, though they arent exactly fashionable.
Not that I own it, though it does appeal to me, assuming its with velour pads.
Armaegis
Modern Modder Man of Manitoba
HTML... uphill, both ways!
- Oct 18, 2009
Though some sources have lousy output impedance, so going into a low 16ohm load means they might only be getting a fraction of the output.
- Mar 20, 2010
Thats true, though if your device is that crappy, time to upgrade.
monkeyboylee
- Nov 7, 2012
Hiya - i totally disagree - my COP's give me far better sq with my E11 than straight from my clip+, it just seems so much cleaner. The Clip+ is rockboxed and i read to keep it at 0db (line level?) and use the amp volume from there - so so much better!
coldmack
- Jul 15, 2009
How does the COP stand when it comes to accuracy and balance?
yokken
- Sep 9, 2012
That's pretty much the opposite of the COP. They have a lot of bass and I have noticed a loss in resolution coming from my HD650s and DT880s. "Accurate" or "balanced" are not words I would use to describe these. They are fun, aka purposefully unbalanced.
- Mar 30, 2012
yar, most Bass Head cans are fun and Pourposefully Un balanced!
coldmack
- Jul 15, 2009
Thanks, so you would call these cans for the bass fans, just to be clear?
