All
I notice the DT880's are available in three impedances, (from memory) 32ohm, 280ohm and 600ohm (..thinking of the DT880's in all-silver with a crimson headband
There's talk that the 600 is the way to go, but I'm interested in the other end of the spectrum, the 32's as I will be wanting to also use these from portable sources, eg iMod and iQube, which is geared for <200ohm.
Has anybody heard the 32ohm versions, and have a sound (sic) judgement?
I am very serious about ordering a pair, as I've owned a pair of the older DT880's and still miss them somewhat (you neverknow how good a pair of 'phones are until you sell them, same in relationships, if you grow to take them for granted all you can think of are their bad points, but when they are gone all you can think off is waht was very special about them), whoops, getting distracted there..
I guess I'm worried that the SQ on the 32's might be a little thin sounding, with an unwanted increase in top-end brightness, and brightness overall.
And another (related) question. I have some mini-jack adaptors with built-in resistors I bought from Jan Meier which if I remember right were rated at 120ohm ea (and can be piggy-backed). If you don't know what I'm talking about viz the Ety ER4P>S resistance cable. My question is if I buy the 32's and add two 120ohm adaptors (for a total of 272, ie ~ 280 ohm) will this make these DT880's identical to a pair of 280ohm DT880's for all practical purposes, or is that not the case?
Kind regards
