haloxt
- Sep 26, 2008
I also get a similar problem playing back music on Mediamonkey, thought it was just me. I haven't tried fixing it though so can't help ya :[.
Your soundcard may or may not have NATIVE asio support, it just depends on whether the drivers were written by your soundcard manufacturer. If you are using onboard SC, just use ASIO4ALL. Send me a PM if you need help setting anything up but most of the info you need should be there with the link I posted above.
