Best way to connect DT770 80 Ohms to PS4?
Sep 30, 2015 at 1:44 PM Thread Starter Post #1 of 5
ashtiany
Got a pair which I use for the PC but would like to try them with my PS4 too!
I doubt the controller would drive these and would like to take advantage of the optical out.
What's the cheapest and most effective way?
Sep 30, 2015 at 2:20 PM Post #2 of 5
Schiit Fulla is supposed to work with the PS4 (through USB), or something like the original E17 with Optical In would work.
Sep 30, 2015 at 2:23 PM Post #3 of 5
An Astro Mix-amp and a dedicated headphone amplifier (FiiO A3), would give you headphone surround sound.
Sep 30, 2015 at 5:15 PM Post #5 of 5
The Astro Mix-amp is somewhat maxed out try to drive the DT770 250-Ohm headphones.
Technically the DT770 80-Ohm is suppose to be easier to drive then the 250-Ohm version.
I guess recommending the FiiO A3 is more a precaution (extra safety net?).
So try the mix-amp by it's self, you can always order an extra amplifier at a later date.
