I contact them too....and they will send me another pair....will try do a little faster review of them....but i do not got any explaination, they just look surprise and say they will ask manufactory to ''find out the problem''.
Mine perhaps is a bellsing cause it have 32 257 write on it, not the B logo tough (do we really need more confusion lol).
Well, technically 32257 is a Knowles number (ie RAB-32257), which everyone copies and clones. So Bellsing will have their version of a 32257 BA, Sonion has their version of a 32257 BA, Tehnz has their version of a 32257 BA, Acme and Widget Inc has their version of a 32257 BA, etc. There could be 20 different BA drivers from 20 different BA companies that all say 32257, because they were all originally reverse engineered and copied from the Knowles RAB-32257.
In theory, if every one were perfectly reverse engineered and manufactured in the exact same way using perfectly identical materials, then they
should all sound similar to the Knowles RAB-32257. But that is usually not the case at all.
Personally, I think here's what happened (
hypothetically). And unfortunately it is all too common in outsourced manufacturing:
1. A company contracts with a Chinese factory to make 1000 earphones. All they tell the factory is that the earphone must 1. come in 2 colors (black and amber), 2. be made of acrylic resin, 3. have a mmcx socket, 4. it must use a 32257 BA driver, and 5. they must be completed in 30 days.
2. The factory then sources the parts. But they cannot find a supplier that has 1 brand of 32257 driver in qty 1000 in the time requires. They are, however, able to quickly locate (250) Bellsing 32257, (400) generic 32257, (250) Tehnz 32257, and (100) Sonion 32257.
3. The factory makes and delivers the earphones within the 30 days, and gets paid.
Well, here's the problem - the original factory contract bid. Instead of saying "
it must use a 32257 BA driver", they should have said "
it must use a BELLSING 32257 BA driver".
This happens much more than you know. For example, when HP contracts to make a laptop, they just say the motherboard "must have a 4.7 uf 250v capacitor". They don't care if they're generic brand, Panasonic, Rubycon, or whatever. In theory, ALL "4.7 uf 250v" capacitors should be exactly the same. But the reality is that each company's capacitor is just a tiny bit different. These minor differences are usually chalked up to margin of error (ie +/- 2% ratings), which is fine for capacitors.
But us audiophiles are arguably insane, and for us that is not acceptable. Most agree that a Knowles BA sounds slightly different (better) than a Bellsing BA or generic BA. It could be the treble is just a bit smoother on the Knowles, or the bass just a bit faster. And it's not in our heads either (at least not always) - Knowles DOES use the highest grade of polymer for their diaphragms, the highest purity of wire for the voice coil, a better grade of steel for the shell, the closest manufacturing tolerances, etc. That comes at a high price though, but it does have an impact on the end result.
The point is that, with regards to the multiple different types of KB Ear F1, that there WILL be minor differences between the drivers. What those differences are, and which driver is the 'best' of the bunch, is unknown at this point.
Personally, I would argue that the genuine Bellsing (with B logo) is the "best". Because Bellsing is actually the closest in technology and quality level to Knowles. So close, in fact, that it has been long rumored that Bellsing actually manufacturers some BAs for Knowles (yet stamps them Knowles). If this is indeed true, then the way I see it, if Bellsing is good enough for Knowles then they're certainly good enough for me.
Again (speculating only), the ones I would personally be suspect of the most would be the generic ones with NO known manufacturer (ie no logo or name or way to trace them at all). Those could have come from literally anyone or anywhere, using who knows what manufacturing processes. It may not even be made in an actual BA factory, but some shady setup. But that's true of most totally generic items.
Personally, I think the Tehnz will sound noticeably different than the others. After all, it is twice the physical size of the Knowles RAB-32257. The Bellsing is exactly the same size as the Knowles RAB-32257. You can't clone something and double the size and expect it to sound the same. If I reverse engineered and cloned a KZ 6mm micro driver, but I made my clone a 12mm driver, you can bet your last dollar that my 12mm driver will sound very different than the original KZ 6mm driver.
Anyways, I guess we'll find out more information as we hear back from KB Ear and more information starts rolling in from other reliable sources.
