Best sound clarity for £130-40ish
Oct 20, 2012 at 3:53 PM Thread Starter Post #1 of 9
sootom
i want some new headphones that produce good clarity for around £130 including amp if one is needed so its quite a tight but i cant try them out cause i live miles away from anything.
are there any headphones that you can easily pick out one instrument with good sound stage for around £130-40ish
thanks
Oct 20, 2012 at 4:07 PM Post #2 of 9
Etymotic ER4P if you don't mind IEM.
Oct 20, 2012 at 4:11 PM Post #3 of 9
how are they for sound stage? i looked at some revews and saw i had a thought. i might not just want clarity but just the abilaty to have good sounding but the be able to pick out each instrument. i first encounters this with some headphones i cant remember but ever since then i have ben spending mony on £20 headphones and being disappointed so that might be it
Oct 20, 2012 at 4:15 PM Post #4 of 9
Surprisingly good for IEM; crap compared to high-end (>$200) full-size headphones.
Oct 20, 2012 at 4:49 PM Post #5 of 9
Ety's have amazing instrument separation so picking apart instruments is very easy.  However, they have a very "in-your-head" so you'll feel like you're sitting in the middle of a well-defined orchestra.
At that budget, alternatively, the Fischer Audio DBA-02/Brainwavz B2 are also good options for clarity and a decent soundstage.
Oct 20, 2012 at 4:59 PM Post #6 of 9
Are you looking for iem's?
If so then I'd recommend a phonak pfe112 (these can be bought new cheap nowadays) with the grey filters. It's slightly better than the dba02 mkII and a lot better than an entire sack full of other IEM's (in my opinion). I should write a comparison or a biggish review for these iem's as I find them so impressive. Hmm, something to do...
Oct 20, 2012 at 5:46 PM Post #7 of 9
ER4 then
Oct 20, 2012 at 6:10 PM Post #8 of 9
I'd like to add sound stage and instrument separation are different terms (to me at least)... the ER4 is unbeatable for instrument separation. You will hear absolutely everything going on, all at once. No muddiness, fuzz, haze, etc.
