campos
- Oct 12, 2012
What's the best out of these four? Vote Please
As an alternative to soundcards, a good asynchronous USB dac will wipe the floor with just about any internal soundcard when it comes to SQ. So unless you need the extra options that a soundcard gives I'd take that into consideration.
It is entirely possible to achieve transparent DAC performance (= indistinguishable from an "ideal" DAC in blind testing) with an internal sound card if there are no interference problems in the machine the card is installed in. When interference is indeed an audible issue, an external DAC is preferred, but it does not necessarily have to be asynchronous. On the other hand, a sound card has more features, and is often cheaper at a similar DAC performance. "Wipe the floor with any sound card" (including ones you have no experience with) is just audiophile hyperbole.
Exactly, internal soundcards, especially when talking about flagship soundcards, are very high performing, and easily outperforming external DACs that cost quite more. Like it was pointed already, EMI issues are really the only thing to worry about, and that's related to the environment the soundcard is installed and not the soundcard itself.
For headphone usage, the STX has lower impedance output (10 ohm) than the Titanium HD (36 ohm), making it more suitable for lower impedance headphones.
Agreed. If you have a machine with good components, an internal sound card can work very well.
Those with dedicated amp, like the STX are better, but only capable of driving >80 ohms, otherwise there's an impedance mismatch. If you have a high impedance headphone, I'll say its a pretty good deal, the STX.
External DACs solve this problem in the sense that you have to get an amp along with it, which is usually a better power source (much lower output impedance). And that gets translated to "external dac's are better", which is obviously not true.
The only problem I've seen is that sound cards, and for that matter, integrated sound chips as well, only seem to run headphones in a certain range of impedances. Too high, not enough volume and body, and too low sound funny.
I did some AB testing with yesterday with my Grado SR225i (32 ohm) plugged up to the headphone output on the STX, and with the FiiO E17 plugged in between (using it's headphone amp only). I really couldn't be certain that there was a significant difference. So depending on the actual headphones and the external DAC/headphone amp setup, I wonder if in the <$200 budget range whether or not it works out to be better going with the external over the STX even when there is a slight impedance mismatch. Yet I do like the STX DAC output better than the Fii0.
Both of you are ultimately right. Some reasons:
- The STX (and all of the other Asus "amp" cards afaik) uses the TPA6120, I have yet to see a solution with Zout lower than around 10 ohms. This is fairly low all things considered, but if you have a reactive load, it will cause more deviation than with a stable load or the same reactive load on a 1 ohm (or lower) Zsource. It isn't as dramatic as you would expect with an OTL or a receiver, that may have a Zsource upwards of 400ohms though.
- Grado headphones are inherently VERY stable though, and apart from a few of the hoity-toity models really don't care (and even the hoity-toity models will still sound good enough on basically anything with a headphone jack) what they're plugged into, at least in terms of Zsource:Znom interaction.
You just lost me. But I'll take your word that the Grados are very stable![]()
...for gaming and music you probably don't need to spend anywhere near as much money as any of those cards; something simple, like even the Audiophile 2496, would be appropriate. I'm assuming you aren't using the soundcard to drive the headphones in any of these scenarios btw.
Do keep in mind that gaming benefits from a soundcard that has gaming audio features, something Asus cards partially support and Creative cards fully support. Something like a base Creative X-Fi Titanium will do the trick, but output quality is far superior on the Titanium HD, with a middle ground being the X-Fi powered Auzentech cards.
Whoops! I meant to say "for just music" there!![]()
Well, the thread title is "Best sound card ever for Music and Movies?", so you should probably have said "movies" instead of "gaming".![]()
