Head Injury
- Sep 11, 2009
I already recommended the Cambridge Audio DacMagic and Yulong D100 for $500 and under. They're both very solid. There's the ASUS card too but you can't use that.
You need optical in, coaxial in, or USB in. You want your DAC to have RCA outs to feed an amp. Your current amp has a USB in because it has a DAC built in. If you have a coaxial cable (or any extra RCA cable) and a coaxial out on your PC, that's the way to go. Optical would probably be second best, followed by USB.
6moons doesn't lie so much as all of their reviews are highly subjective and very prone to bias.
THD isn't the most important, but it is important. That's the only thing I can find about the Octave, and if it's bad then I don't have much faith in good engineering throughout the rest of the DAC. Some components (tubes for example) are used because they have high THD, but I try to steer people toward quality.
Synergy only exists between colored components, which are best avoided anyway. The M1DAC doesn't have spectacular measurements but they're fine. The frequency response seems very flat, -0.1dB from 10Hz to 20kHz. SNR is a solid 119dB and THD is an inaudible 0.0025%. If the looks are worth it to you, you won't go wrong by choosing it.
okey. if you suggest 500 is pretty enough than please give advices which DAC I should buy for 500.
i need optical out (i think, or usb?) ?
6moon lies ?
THD number is the most important value for DAC's ?
my car audio amplifier has: 0.009% THD (Helix A4)
maybe best synergy would be stay with Musical Fidelity ?
it has a DAC called M1DAC. (on the picture the lower deck)
