Best Smartphone for audiophile Part II (Updated: Mar 2019)
Discussion in 'Portable Source Gear' started by artpiggo, Jun 19, 2017.
Tags:
138 139 140 141 142 143 144 145 146 147
149 150 151 152 153 154 155 156 157 158
  1. jhoffmann
    Why no recommendation for "normal" use? I need just a few hints because I'm looking for a V30 here in germany after I sold my HTC10.
    Regards from germany
    Juergen
  2. artpiggo
    Just meizu 16th + ak xb10 + ak billy jean
  3. Broquen
    If I'm not wrong XB10 does not support LDAC and bluetooth version is 4.1. Nowadays it comes a bit late.
  4. artpiggo
    XB10 has too much stock so they need to find way to sell it off lol.
    Broquen likes this.
  5. Broquen
    Just what I was thinking xD
  6. TooPoorForHiFi
    QUESTION! For those that uses your Phone w/ LDAC BT
    If a Phone supports LDAC, Does the Sound Quality over LDAC get affected by your Phone?
    Example. Would an LG V30 streaming Over LDAC has better sound quality oppose to a Samsung Galaxy w/ LDAC streaming?
  7. Broquen
    No. The SQ is not affected.
    TooPoorForHiFi likes this.
  8. DonCorras
    Guys I need a little help, I'm thinking to buy a new phone and my choices are meizu 15 plus and the meizu 16th, what do you guys think? Or any other recommendation.
    Thanks
  9. VonBoedfeld
    Did any of you know anything about the "LG G7 Fit"?
    It should have the same audio components as the LG G7 Thinq, but costs only 230 € in Germany, which, if that were true would be a great bargain.
    It seems like the phone is only available in Germany: https://www.lg.com/de/handy/lg-G7-fit
  10. dacari
    All is true and not only limited for Germany, even it will be re-lauched¿? under Q9....but there is a problem and a major one...the battery. Unless you're a very conservative user you won't reach the end of day.
  11. Muger
  12. artpiggo
  13. ElRubiales
    I was looking for something cheap and pre-owned to listen to music (50% jack 50% bluetooht). I could find an axon 7 for € 80 and an iphone 8 for € 100, some other better alternative?
  14. artpiggo
    lg v30,g7
  15. ElRubiales
    I was looking for something economic and Seninuevo, and I will use it for the gym, not more than 90-100 €/$
