Best Smartphone for audiophile Part II (Updated: Mar 2019)
Discussion in 'Portable Source Gear' started by artpiggo, Jun 19, 2017.
Tags:
126 127 128 129 130 131 132 133 134 135
137 138 139 140 141 142 143 144 145 146
  1. vishkenpachi
    If I am okay with Chinese models . Any suggestions please ??
    I currently use an iPhone X which i feel is worthless with my oppo s . Any suggestions In buying dac amps is also appreciated .
  2. Thearcade12
    If you are okay with carrying an extra device then there are many options including ifi products.
    https://ifi-audio.com/products/xdsd/
    andrewski likes this.
  3. artpiggo
    Vivo xplay6
    Or ifi idsd bl
  4. lxlx
    or shanling m0, DAC and standalone
  5. Ymer
    Hello guys.
    Upgrade time, my V20 is a mess with all sorts of typical LG problems so I'd rather not go v30, G7 or V40.
    I really like the Huawei P20 Pro. Are there any good USB-C dongles out there that perform as well as LG phones, even if they're expensive? Or is the HP20P a total mistake for audio?
    Thanks a lot!
  6. EpicEric6
    I’ve been using Vivo Nex S for a few months. Very happy with its audio quality. Other pros including nice screen, good camera and large battery. However the touch screen is not as sensitive as other phones, and Bluetooth audio is buggy and will stutter with my WH1000-XM3. Anyway, I’m about to jump boat to a G7 and sell the Nex. Let’s see how it goes.
  7. bencherian
    Am not sure any small dongles do as good as LG but if you have easy to drive iems take a look at Hidiz Sonata type c to 3.5mm dongle. Also VE Odessey is there which is more powerful but doesn't have that much clarity as hidiz Sonata as reviews says.
    I think it's time to move to dongles time. Either way good audio mobile phones are losing software support like the LG one or many are losing headphone jack.
    Given that OnePlus 6t removed headphone jack and considering the fame of OnePlus in market i think in short time many earphone companies will bring with type c earphones. Just a guess.
  8. bencherian
    Well try LG V40 also. Either way please do a overall comparison of LG vs Vivo emphasizing audio department
  9. ohsigmachi
    Just wanted to chime in here and say my LG V30+ has been stellar for the last 6 mos. It sounds perfect (for me) with my TFZ King Pro IEMs and VSonic GR07s (37th Anni special edition) while out and about, but also drives my Nightowls and X2HRs flawlessly while puttering around the house.
    It also pairs very well with my Sony WH1000-XM2 for travel, LDAC support makes the sound so transparent and accurate. Bluetooth pairing is always very fast (damn near instantaneous) and easy.
    The V30+ comes with 128GB of internal storage, and I added an additional 128GB SD card for half a Terabyte of storage, so I have downloaded a ton of lossless files from Tidal and it makes listening in patchy cell reception areas very easy.
    Extremely happy with it so far. I had a G4 and a G3 previously and liked them too, but they didn't have the same quad dac feature set of the V30. My G4 died an an fortunate death and the hands of my offspring (#dadlife), so I had a Note5 from its initial release until 6 months ago. The LG was a big upgrade as far as sound goes.
    One additional note, streaming bluetooth Tidal from the V30 to my car sounds orders of magnitude better than streaming Prime Music from my Note5. It is seriously night and day, My son got in the car and the music started and he just spontaneously said, "Wow, this sounds awesome! Did you upgrade the stereo?"
  10. heavyharmonies
    Not to be pedantic, but 128 + 128 = 256 = a quarter of a terabyte, not half a terabyte.
    I believe the technical term for your storage capacity is "a crapton of music". :beyersmile:
  11. RockStar2005
    So you really think it sounds as good or better than the V30 Exit??
  12. ohsigmachi
    You are correct, and I was wrong twice. My memory isn't what it once was. I actually put in a 256GB sd card, so I guess I could say I have "almost half a terabyte"?? 384gb... Who can remember that wierdass number? I'll stick with the more technical term (crap-ton) from here on out.
  13. misterawesome
    I'm looking for some help identifying/simplifying the role of DACs as phones phase out headphone jacks. I've been using an HTC 10 for the past few years and bought it largely b/c of the high quality onboard DAC. I'm looking for my next phone and am leaning towards the OnePlus 6T or Pixel 3. I've read that the Snapdragon 845 has a built-in DAC, and that the 6T has an analog DAC as part of the USB C port. My goal is highest-quality sound without spending hundreds on external headphone DAC - should I be looking for a USB-C-3.5mm dongle with a built-in DAC? Does a USB dongle "cancel out" the onboard DAC (whether it's from the processor or in the USB port itself)? The 6T is new enough that I'm not finding a lot of info about headphone sound quality (just the crappy speakers) - any insight would be appreciated!
  14. bencherian
    You can start with Hidizs Sonata HD 2 . Pretty good one. Don't expect LG G and V series loudness. But it is better than almalm all mobile dacs out there. Cost is 29 dollars after 10dollar discount from their official site. Head-fi has some good reviews about it too.
    Ve Odessey is also another one which is cheaper at 10 dollars only but sound quality wise Sonata has the lead.
    If you want similar to LG G and V series audio then Audioquest dragon fly black should be looked. But it's bigger of a pen drive size plus it needs extra usb otg cable and also it is quite expensive
  15. gr8soundz
    Most Snapdgragons have built-in audio but some manufacturers use a separate DAC chip for better quality. Similar to Intel CPUs with integrated graphics vs ATI/Nvidia graphics which are 10x better.
    Software determines which chip handles the audio but we're still in the Android phase where those details are being worked out. Afaik, connecting a USB DAC overrides the internal chip but the only app that can force USB audio output (for devices that support it) is still UAPP.
