Best Smartphone for audiophile Part II (Updated: Mar 2019)
Discussion in 'Portable Source Gear' started by artpiggo, Jun 19, 2017.
Tags:
119 120 121 122 123 124 125 126 127 128
130 131 132 133 134 135 136 137 138 139
  1. singledot02
    has anyone tried to pair the RHA CL1 to LG v30? - how is it guys?
  2. Cortlendt
    How much LG G7 One will cost exactly?
  3. docentore
    Not that I've heard LG or Vivo, but I wouldn't rule out ZTE Axon 7 from there. Sikilar chipset as xplay6(SD820 + 4GB/64GB) but we're have custom ROMs up to Android 9 now.
    AFAIK xplay6 is stuck on 7 and no root method?
    Axon has premium DAC as well - AKM4490, compared to what I own and owned (couple of DAPs and DACs) it does deliver high SQ.
  4. artpiggo
    That's normal feedback when you still not tried xplay6.
    andrewski, docentore and TheUnknow like this.
  5. seanc6441
    I assume this is common knowledge on here now but I compared the V20 (non B&O version) to the V30(+) and the difference in sound is subtle but there.
    The actual sound quality is equal overall IMO, but the signature is slightly different.
    I always characterized the V20 as having a slightly bright tilt from mids to lower treble, except for the slightly elevated mid bass which gave a fuller bass response.
    While this gave the V20 a wonderful impactful bass and clear detailed highs, it did leave a slightly leaner presentation of the low mids.
    The V30 drops this bass emphasis for a more neutral response, which is turn makes the low mids more in balance. The upper mids and lower still have the brighter tilt but again it's not as apperant because of the more neutral response below 1khz. Treble is roughly the same on both devices, it's clear and extended flat and doesn't seem particularly emphasised or coloured. It's an accurate treble response.
    So overall I'd consider the V30 the more neutral of the two with a hint of brightness. While the V20 has more colouration in the bass and thus has a slightly warm-bright tilt.
    andrewski and Thearcade12 like this.
  6. jody2k
    In terms of SQ there is no difference between the 2 phones, it's exactly the same dac just different colourations trough the drivers/software. You can set it to your own preference using any equalizer software
    Preferable: viper4android as it's the best EQ you can get on a android phone
  7. seanc6441
    Yes that's what I eluded to in my comparision. Also with the 3 filter options available you can change the sound in that manner. If only there was a parametric EQ baked into the OS then this would be the perfect DAP imo.
    How easy (or hard!) is it to root the LG V30+ H930 if you have any idea?
    I've never rooted before but if the instructions are straightforward and my model is not troublesome to root I may consider it for V4A because I'd really love to use a full EQ with spotify.
    Currently I'm using RE EQ which is very good for a graphical EQ but it's no match for a parametic EQ.
  8. 9611838416m
    Have you used the xplay5 elite? Is it any better than the xplay6? (asking because I might have a chance to get the xplay5 elite)
  9. Thearcade12
    I read on Chinese forum ie. soomal that xplay5 elite is little better then xplay6. I think you should go ahead and even if you don't like the phone overall you can always use it as a cheap dap.
  10. artpiggo
    Never tried but pretty sure it has shared the same direction of vivo house sound.
    Maybe wider soundstage (but less 3D) and more treble orient than xplay6
  11. SystemPA
    Hi Guys, what do you think about Galaxy Note 9 ??
  12. docentore
    Probably you are right, hence I mentioned that I haven't heard it.
    But no root and blocked bootloader is stopper for me here. That's why I've moved away from MX4 Pro (it had root but locked bootloader) although it was very musical.
    How would you compare xplay6 to MX4pro? Similar DAC.
  13. cj3209
    I've been using with Tidal hifi, Roon MQA Tidal, and music files directly from the phone. Via either my iBasso IT4 or KSE1200, sound is pretty good. The Note 9 has some software adjustments like Dolby Atmos, UHQ Upscaler, Tube Amp Pro, and an equalizer that fine tunes the sound. It's not the equivalent of a great DAC like tdd he LG phones but it's pretty competitive.
    It sounds very good to my ears.
  14. SystemPA
    Thank you Man.
  15. fabrusso80
    I have a Fiio F9Pro and I'm searching for the best phone that can give the best sound to my headphone.
