Best Right-Angled Mini to Mini?
post-217687
Thread Starter
Post #1 of 8
Jackangel
I have a Meta42 (AD8620) on the way.
My primary PCDPs are an SL-SW860 and a D-25s.
I've got a pair of DT770s and a pair of MDR-7506s.
I want good bass with a full, rich sound.
I'll need a mini to mini cable to go from my pcdp to the meta42. It should be rather short (3 feet will suffice, I think) and not stiff, because I want it for a portable setup (sitting in jacket/pants/shirt pocket while I'm moving). I've read a few threads just now, and it seems the Markertek cables are great for the price.
But, are there any quality right-angled mini to mini cables available?
Should I buy the straight-plug and then get 2 right-angle adapters?
If so, is any such adapter good enough?
Or should I just make my own cables? (I'll consider that, but if I can get something good for $15-20, I'd rather do that).
Is there someone on head-fi who makes cables for others?
Advice is appreciated.
post-217695
Post #2 of 8
Taphil
I was also looking for a right-angle connector, and I guess the only one is made by Switchcraft, available from Markertek (http://www.markertek.com/MTStore/pro...BaseItem=SW280). I ordered 2 and Canare Star Quad 4-conductor L-4E6S cable to make my own (and my first DIY project) mini-mini cable. I think that's the connector lextek used for his cable.
post-217741
Post #3 of 8
lextek
Yup.
35HDRANN
post-217992
Post #5 of 8
Jackangel
Ok...so I can pick up 2 of those switchcraft plugs and some 4-conductor cable in whatever length I desire. Other than that, all I need is a soldering iron and some solder...and that's it?
Is it really so simple that when you look at the parts before you, you know what to do? I'm thinking of which wires should be soldered to which points on the plugs? If there's a guide somewhere, do tell. Otherwise, I'll ask someone later, when/if I get the parts.
post-217999
Post #6 of 8
lextek
3-conductor wire. As long as the same wire goes to the same contact on both connectors. It makes more sense when you see them.
post-218083
Post #7 of 8
LobsterSan
MOT: kuboTEN
JackAngel: if you find any guides or any more information on DIY-ing cables, please let me know (if not in a thread, then in a PM or email). I would really like to get some projects started if they are simple enough... but I fear I will miss something and then make my end result sound crappy.
post-218175
Post #8 of 8
puppyslugg
If you use the Canare quad cables, there are 4 condutors+shield. If I recall correctly, there are 2-blue and 2-clear/white. Connect one of the pairs to the ground of the plug and other end to the ground of the other plug. Connect the other pair to the center conductor of both plugs. Connect the shield on one end to the same ground as above. "Float' (NC) the other end of the shield. You can also connect the 'float' end thru a small cap to ground. Double check with VOM.
