Best Replacement Pads for M50x's?
May 18, 2015 at 7:29 PM Thread Starter Post #1 of 4
MaztotheUla
Just bought the M50'x's havent really compared the sound yet but the pads are much more harsher compared to my HD 439's. Im considering buying velour earpads, and I'm confused between the sound professional pads or the shure 940 pads. Suggestions? Thanks
I'll probably purchase the HD 558's next, as sennheisers are going to be my preferred choice of headphones lol.
May 18, 2015 at 8:44 PM Post #2 of 4
NA Blur
The Brainwavz HM5 pads also fit.  Keep in mind that velour pads subtract a significant amount of bass coupling to your ear so the headphone will not sound as bassy.
These for example:
http://www.mp4nation.net/brainwavz-replacement-memory-foam-earpad-red-velour-suitable-for-large-over-the-ear-headphones
They feel so good on the ears, but alter the sound signature of the M50 too much for my liking.
May 18, 2015 at 8:56 PM Post #3 of 4
MaztotheUla
These for example:
So you don't use it? What type of music do you primarily listen to
