Best in-ear wireless Headphones
Aug 4, 2018 at 11:19 AM Thread Starter Post #1 of 7
rick81
Hello everybody! I'm searching for the best in-ear wireless headphones on the market, the best sounding, it's not important if it has noice cancelling or not. Budget 200 dollars
Thank you!
Aug 4, 2018 at 12:25 PM Post #2 of 7
Try Sony WM1000X (sorry this name may not correct typing).
Sq is Okay for wireless in ear.
Price as your target.
Note : only bass is a deal breaker to me. I need a slight less bass (but almost other even more bass as like bose)
Aug 6, 2018 at 8:11 PM Post #4 of 7
I read about it and it has a lot of problems, with disconnections and delays with videos, has it been solved?
Yes. I forgot to tell. That is one more bad thing. You laydown with one ear touching your bed, connection lost.
For less delay you must chose a bt headset for gammers.
Aug 12, 2018 at 5:19 AM Post #7 of 7
I was very impressed with the 1More iBFree wireless headphones (although they do have a wire connecting the two headphones together).
I've been getting some good results with the SoundPEATS Q32's. Bluetooth 5.0, great battery life and a decent sound quality.
I really rate the Apple Airpods very highly. Although they're expensive I think they're worth it from both a sound quality and convenience point if view.
If you're not too bothered about cables you could also try the rather excellent Aqua bluetooth headphone amplifier with a good quality pair of wired headphones - you get the convenience of bluetooth with the better sound quality of better in ear monitors.
