Best IEM tips?
Mar 2, 2020 at 4:04 PM Post #766 of 1,577
davidcotton
X-CANs and HDAMs
None for me - had to get custom molds made
Seriously starting to think about getting eartips done for each individual iem I've got/get. Wouldn't be that much more than three packs of comply in the uk as it is and would save mucking about :) :frowning2:
Mar 3, 2020 at 9:44 PM Post #768 of 1,577
ranfan
Saitama
Sedna EarFit Light Short is my favourite
I have a very average ears with straight short canal. So universal monitors usually feels like wearing a custom. And with this tip it's the most comfortable so far, and the wider hole + short length allows for clear transmission, clearer than otherwise
Mar 3, 2020 at 10:51 PM Post #769 of 1,577
Makahl
São Paulo
Hey, just a heads up about the differences between the Sony Hybrids that you get from Aliexpress and the OG one. I got the OG via a forward service from Japan and there are some differences:
Aliexpress clone has the stem more translucent; the green color is a bit darker; the top-umbrella is flat whereas the original is more rounded; material-wise it's less rubbery. Sound-wise it's less sub-bassy but overall very similar.
Since, there are a lot of clones out there, you can find the original Sony hybrids in 2 packs, the EP-EX10 ($10-15) which is a pack with SS, S, M, and L tips and the EP-EX11 ($7-8) which comes with 2 sizes of your choice. I got the clone on Aliexpress for ~$3.50 and it came in a pack with 3 sizes S, M, and L.
I like them better than the Final E and Starlines for narrow bore tips type, definitely they worth a try if you're looking for a bassier tip.
Mar 9, 2020 at 6:51 AM Post #770 of 1,577
talponne
Previously known as PreetyAdrian
Romania
Hey, just a heads up about the difference between the Sony Hybrids that you get from Aliexpress and the OG one. I got the OG via a forward service from Japan and there are some differences:
Aliexpress clone has the stem more translucent; the green color is a bit darker; the top-umbrella is flat whereas the original is more rounded; material-wise it's less rubbery. Sound-wise it's a bit less sub-bassy but overall very similar.
You can find the original Sony hybrids in 2 packs, the EP-EX10 ($10-15) which is a pack with SS, S, M, and L tips and the EP-EX11 ($7-8) which comes with 2 sizes of your choice. I got the clone on Aliexpress for ~$3.50 and it came in a pack with 3 sizes S, M, and L.
I like them better than the Final E and Starlines for smaller bore tips type, definitely they worth a try.
Very nice tips
I have a pair stolen from a T3 :)
Mar 19, 2020 at 10:10 PM Post #771 of 1,577
assassin10000
CA
https://www.head-fi.org/threads/best-iem-tips.626895/page-46#post-15418889
https://www.head-fi.org/threads/best-iem-tips.626895/page-46#post-15418950
So the small Ikko tips ended up being uncomfortable for my smaller ears canals. When I ordered them I thought they were 11.2mm which would have been closer to my ideal size.
A couple days ago I came across the Misodiko tips which are a similar design but their small and large size tips are just a bit smaller. They're also available on Amazon US or AliExpress. I've ordered them in small to try.
Ikko tips: S 11.5 | M 12.5 | L 13.5
Misodiko: S 10.9 | M 12.4 | L 13.0
Well, these Misodiko type tips finally showed up from AE. Unfortunately sizing isn't 11mm but 12mm O.D., which means just like the Ikko tips they're uncomfortable for me.
Nice tips, just wish they were smaller.
Edit, link:
https://www.aliexpress.com/item/4000482730406.html
Mar 27, 2020 at 5:05 AM Post #772 of 1,577
AlwaysForward
My Sugru customized Spinfit tips are the absolute best tips I've used, and I have to say that I also prefer them even to my custom in-ear monitors.
Given the fit and sound quality I can achieve with this hack, I don't ever see myself purchasing customs again.
Comply aren't bad in terms of comfort, but they are nowhere close to these in terms of durability and sound quality. And, I hated having to replace the Complys regularly. These will definitely last much longer.
Yup I’m gonna try that for sure
Apr 12, 2020 at 9:57 PM Post #774 of 1,577
Casine
Hi, Found out today I was a proud member of the big ear club! I was wondering if anyone had meauserments of the Final E in LL. I can’t seem to find this info. Or if not, how big they are compared to the large spiral dot and sedna, both 14mm. Thanks
Apr 12, 2020 at 10:02 PM Post #775 of 1,577
assassin10000
CA
Here you go.
inner bore looks near to 4mm (3-4mm)
@hakuzen to the rescue again! Muchas gracias mi amigo.
I got a reply from final audio:
Thank you for contacting us.
Here are the outer diameter and inner diameter of each size.
size: outer diameter, inner diameter
SS: φ10.4mm, φ3.4mm
S: φ11.1mm, φ3.4mm
M: φ11.9mm, φ3.4mm
L: φ12.7mm, φ3.4mm
LL: φ13.4mm, φ3.4mm
Apr 12, 2020 at 10:14 PM Post #776 of 1,577
Casine
Thanks, what a cool forum. Yeah that might work. My 13.5mm Starlines are a bit small, but these alone or with a little foam in them should work. I also realized I could buy the e1000s for 10$ more than the tips, kinda exciting.
Apr 21, 2020 at 3:04 AM Post #778 of 1,577
Fabaaroan
I want to order some eartips (azla and jvc spiral dot ++). As I live in France it s more difficult to buy this particular eartips
I check on Amazon japan and there is no azla ear tips in stock.
Have you an idea when I could order one .
I saw this website https://www.mtmtaudio.com/collections/silicon-ear-tips
Perhaps some Head fier know this website and order some eartips .
Otherwhise i will wait a little
Apr 21, 2020 at 5:51 AM Post #779 of 1,577
Davidibiza
Ibiza
I bought from them a couple weeks ago. Spent 30 USD and they don't even give you a tracking number for your shipping. So I don't know when I will be getting them. Had I've known I wouldn't have bought there.
