Best IEM tips?
Jul 13, 2019 at 10:12 PM Post #587 of 1,577
RollingPeanuts
USA
Anyone happen to know what type of foam eartips these are?
Jul 13, 2019 at 10:18 PM Post #588 of 1,577
Cevisi
Germany
Those are pretty much what I'm looking for. Thanks!
Yes, you are correct. the 45 in 145 stands for 4.5mm bore size. I looked at all their product line in their webpage, and notice varieties of bore sizes they offer.
I just ordered a set today to try with Andromeda, which works great with 4.5mm bore size. I like the Spinfits a lot. Something about the materials, and design are well thought out and the sound output will prove it. Probably the best sounding tips I've heard as of late.
Also, I notice a difference in sound presentation of different shapes of tips. Like a difference between olive type shape and umbrella. For example like these two types of Spinfits. I notice difference in bass extension response.
This would be an olive type shape
This would be umbrella
the inairs also sound very nice whit everything better then my spinfits spiral dots symbios complys and tons of no name tips give it a try
Jul 20, 2019 at 12:31 PM Post #593 of 1,577
Cevisi
Germany
Update: Forget about the 4.5mm size, the bore is still pretty narrow. 4.5mm is the portion that holds the nozzle, and the bore is narrow up top. And such narrow bore size doesn't work for Andromeda.
yes its pretty narrow
Jul 20, 2019 at 7:19 PM Post #595 of 1,577
god-bluff
God's own county
Got to be Blackbird foam tips. Much harder wearing than comply whilst retaining the sound signature of the earphones much better. Cheaper too but I believe only available in the UK?
Jul 20, 2019 at 7:44 PM Post #596 of 1,577
David Kleinfeld
hong kong
Hi Guys,
I am looking for an X Large Silicone or foam tip (15 to 16 mm). I have been using 14 for quite some time now, but end up with a bit of loose fit. I think that's the issue with using large iems for extended period of time also. Would you have any idea if this can be found and if so where?
Thanks in advance
Jul 20, 2019 at 10:26 PM Post #597 of 1,577
assassin10000
CA
Hi Guys,
Thanks in advance
Largest I've seen are these 14.5mm tips:
https://www.head-fi.org/threads/chinese-asian-brand-iem-info-thread.820747/page-1529#post-14886109
Jul 21, 2019 at 2:06 PM Post #599 of 1,577
pstickne
Portland, OR (USA)
Looking for some double-flanged tips because I feel like they'll provide me the best isolation/fit judging by my concert earplugs which are the double-flanged Earpeace ones standard size (linked below). The triple flanged ones go way too deep into the ear and are uncomfortable.
https://www.earpeace.com/products/earplugs?variant=43678121796
So many different style of double-flange, depending on ear shape.
Spinfit CP240 is example of a really small inner flange and RHA has much fatter dual flanges, eg.
Jul 21, 2019 at 3:00 PM Post #600 of 1,577
davidcotton
X-CANs and HDAMs
