Blackground
- May 16, 2016
I have the original. I believe the BL only has minor improvements. But look how low the original is on the used market and it may alter your perception of the BL's value.
Okay, here are a few of my thoughts on other stuff under $500. Bear in mind these are just my subjective opinions.
- The ultra-budget Koss KTXPRO1 is 90% as good as any headphone. (I think the refinements of even the best headphones only account for a small percentage of the sound beyond what the KTX can do.)
- Used STAX are the best headphones you can get in this price range.
- My JBL LSR305 speakers sound far more realistic to me than any headphone.
(To see a list of headphones I have owned and heard, check out my profile.)
As for comparing things...I suspect that the amp in the iDSD is coloring the sound even when I use it as a DAC/preamp for speakers, so I bought a Schiit SYS passive preamp to level that playing field when comparing most DACs and DAC/amps. (Chord DAC/amps are an exception because the amps in them are in the DAC's analog output stage, so they can't be bypassed and are more akin to the amps that dedicated DACs use to send the signal to an external amp.)
One advantage the iDSD has over the Mojo is much higher maximum output power...which is only really relevant for very hard to drive headphones or when you're doing extreme bass boosts, which requires a lot more power than normal.
Also, I've only used the Mojo as a DAC/amp for headphones. (Never used it with an external headphone amp or speakers.)
You know I actually read that on a review of the black label recently, the user was essentially saying the same thing about the amp on the idsd bl.
I would've done the same thing if I were in your position. My other principle is dedicated components over combo's. Although I will admit there have been some exceptions, i.e. Idsd.
I'm definitely going to check out those you listed, you do have quite a list lol. I too am looking more into speakers, as that will more than likely be my next major purchase.
