Best dac/amp for PS4
Page 3 of 3
  1. OneHappyOrange
    Does the Sabrent work?
  2. samuelfox97
    Yes I just got it in yesterday and it works perfectly. Now I'm debating on wether I should get the magni 2 uber version to pair with my modi 2 uber or not get it and save an extra $50
  3. samuelfox97
    So I finally received my modi 2 uber and magni 2 uber. I get everything setup and plug it all in and set it up in the PS4 menu exactly how you said to and all I hear is this really fast clicking sound when I put my headphones on. No audio comes out, all I hear is this fast annoying clicking sound like something's broken. Any ideas?
  4. overhaze
    The problem with using USB dacs on PS4 is their is a known bug where left and right stereo can be reversed. I suffer from it myself and it is super annoying. Can anyone suggest a USB power dac/amp with an optical in? I'm using my Audioengine D1 right now but the thing is on its last legs and its output impedance is too high for my X2s.
  5. RMA192AK
    If anyone else has this problem in the future, I had the same thing happen when I first tried using a Schiit DAC with PS4 via optical. Schiit DAC’s only support PCM & not Bitstream, so in the “PS4 Audio Output Settings” for output formats supported you need to make sure all the boxes are checked for “Linear PCM 2 ch.”, mine were not and once I checked them everything worked great. All the other formats listed will not work with Schiit or most other 2 channel DAC’s used by Audiophiles.
Page 3 of 3
