wharfrat1
x3 on getting a cheap cd player as a transport and getting a good dac. I will also recommend the DLIII. Now mine is modded and I absolutely love it, but I've also read nothing but positives on the stock model. Plus, if you do want to transfer stuff to FLAC, you can hook up your PC to the DLIII via USB if your soundcard doesn't have an optical/coax out.
I was in your shoes earlier in the year and was really considering getting a new cd player in the 1-2K range. After doing much research, I decided to go with the stand alone DAC, and as stated above, couldn't be happier with the choice.
Now, if you really want to go the CD route, I will recommend as another did to look at the C542. I was very happy using that as my source for a while and you can find new ones for $299 now (I paid $475 for mine.) Good luck with your search.
