Quality of music would be the encoding bitrate and the source where you got it from such as mp3 128kbps or 256 aac or flac. for example. YOu can check this in your player or by right clicking and checking audio properties.
What he means is what format are they on - CD or digital copies. If they're digital copies, where did you get them from - ripped from CDs to what kind of file and bitrate or compression ratio, bought from iTunes, etc.
Recording and mastering quality is another but that's hard to ask for as a blanket statement as they can vary from one album to another, it's just that badly done albums are more common nowadays.
It's not difficult, just expensive. You need to buy a balanced DAC and most balanced cables if you can't DIY them are relatively expensive (likely because the sellers assume you can pay for a balanced amp, you'd pay $300 for a cable).
If you're in SoCal you can check Schiit website - they have a showroom where they have a few DACs and amps set up. They might have some headphones there too so you can probably try whatever's there and you'd have a better idea what you want and what people can recommend based on that (in case the ones you like there are above what you're willing to spend).
That works too, but similar single ended cables from China like the one I'm using now only cost $20 (ie cheaper than the too long cable from Sennheiser; bought it more for it being shorter).
Good morning,
I went into both Tidal and Spotify and tried right clicking and nothing with audio properties. I also went into settings and found nothing. I'd really like to know the bitrate of both these players and the source material I'm listening too.
Thanx for your help!
Good morning,
Good morning,
In tidal and spotify are only at the highest if you set them so otherwise the bitrates vary. most people dont know this and listen at standard settings and are not listening to 320 or loseless as it is not default to listen at loseless or 320. You do this in the settings and streaming settings.
Ty for your reply, I'm not exactly sure what quality my music is at but I listen to everything except for country. Also I chose to get the hd 6xx on massdrop because they seem like a bargain to me. I was also thinking about getting hifiman he400is instead. Is going balanced difficult to do or do you just need the balanced cable? Sorry I'm a newbie regarding this. Also, I live in California, in the U.S.
Thanx.
Yeah. I have Hifi/master set on Tidal and it's Spotify premium. Both set to highest bitrates.
You're right about most people don't know about that as I was one of them. I finally figured it out after a few days.
I just thought I was missing something I wasn't aware of.
I truly do appreciate your response. You guys are quick!
