Go check the S500 thread, but from memory the S500 was considered higher quality than the S400, however the S400 had a MUCH more neutral sound signature. The S500 is supposed to contain some great bass, while the S680 is supposed to be similar to the S400, however with a much larger soundstage, and HUGE BOOMY bass.
I was about to say the HA-S400 already has boomy bass imo, but it doesn't. It has boomy, or just overpowering, mids. People say the S500 is V-shaped. The S400 is mountain-shaped or upside-down V-shaped. I try to pick out details in songs, or just try to enjoy songs, but I can't because the mids are shouting at me and making a big blob of noise that drowns out the actual music.
Oh wow, I wish I saw this earlier, I already ordered the Pro 80, how would you say it stacks up against the HM3? I'm selling my JVC s680 so that would allow me to get both. I really want to save up for the HM5 though since that seems like what I would ultimately enjoy with its wide soundstage.
Don't be concerned. That's a specific situation I was talking about. I was talking about rocking out and air guitar. Those times you want the music aggressive and in your face, and for certain kinds of music. Though HM3 tends to make most everything sound aggressive yet pleasant. The Pro 80s do the aggressive and in your face thing well too, which is why at other times I've been disappointed in the size of their soundstage. You can kind of get the HM3 sound I'm talking about by upping the lows and lowering the 1k area. Or maybe just lowering the 1k area would do it. The Pro 80s are bright around 1k, which helps with detail but hurts smooth pleasantness.
I'm doing my best to describe this stuff how I hear it and without having to constantly A-B different headphones to make sure my words are absolutely 100% correct. We're using words to describe complicated sounds, so being wrong happens sometimes,
especially when trying to very specifically describe sounds.
In simpler terms, the HM3 are darker/warmer yet with a sparkle in the highs so cymbals and things still have life. Pro 80 is brighter overall, and they're so bright around 1k it can get to me a bit. I saw at least one other person in the Takstar thread say similar about the Pro 80s around that 1k zone, so maybe it's just us, but that's how it is.
Pro 80 is the more accurate headphone. But if everyone always only wanted accurate headphones, there'd be no bassheads, or no one would like the DT990, etc. I'll also say Pro 80 is the "better" headphone. It's hard to go too wrong buying a Pro 80.
Though it depends what its intended use is. I said I thought the Pro 80 weighs about 9 ounces, but I looked it up now and it's 12 ounces. That's quite a way from the HM3's (just looked it up) 6 ounces. (JVC S400 is 5.1 ounces.) When I put on headphones, it tends to be for extended periods, so things like that matter. People in the JVC HA-S500 thread have said similar about those for one of the reasons they use them so much. If I'm just listening to talking audio of some kind, I might use my old low-end computer headset since it weighs 2.x ounces and has small pads and a light clamp.
My FA-003/HM5/clone weighs about 10 ounces, but there's something about the way the Pro 80s sit that they feel a good bit heavier than just an extra 2 ounces. The Philips SHP9500 weigh 10.5 ounces from what I just looked up, but they don't feel like that much, maybe because the pads are huge and clamping pressure is so light, and maybe also because of air flow since they're so open. There are open headphones, and then there is the open Philips SHP9500.
