Michael777
I noticed a deafening "pop" whenever I plugged headphones into my HA400 amp, so I decided to take some measurements.
It turns out that this thing pumps out 5.5 volts DC, regardless of input. Here's what a 1kHz sine wave looks like:
https://i.imgur.com/pGlsQzx.png
I disconnected the amp and ran the same test with the sound card output, which is centered on 0 volts as expected:
https://i.imgur.com/3KfM7YW.png
I verified this with a multimeter, and also got the same result testing with a second HA400, so it's not just a faulty unit.
So, this thing has been continuously dissipating hundreds of milliwatts of power in my headphones, which I leave plugged in. Given that they've been plugged in for months, is this likely to have damaged the headphones, by heating up the coil?
If there is damage to the headphones due to the constant heat, how would I tell/what would this sound like?
I'm obviously throwing this amp away, I've had it for years but never realised it could be actively damaging whatever's plugged into it.
