CirrusPilot
- Sep 30, 2012
Hi all, I need your collective wisdom. I was looking for a new set of headphones. I currently own Grado SR60s (which due to their poor cable design has issues with the left side shorting out) and a pair of Shure 115s. I just got rid of my Bose AE2s. I tolerated the sound of the Bose because of their extreme comfort, which is undeniably awesome, and I now want to upgrade, but I have a limited budget.
I picked up a pair of Grado iGi's at a local store, and wasn't impressed at all with the quality. I liked the sound a whole lot, but the cables were very cheap, it didn't have any way to prevent tangles, and the ear tips left a lot to be desired. They weren't uncomfortable by any means, but they didn't isolate well. I returned them because they weren't worth the $90 in my opinion. I don't want another pair of full-sized Grados because I think their cable design is unforgivably stupid. They are allowed to twist, which ruins the cable in short order no matter how careful you are. Grado really needs to go to a single-side cable.
That being said, I picked up a pair of AT M50s on Amazon for a great deal using reward points. I also bought a pair of DT770s at a local music store. I kept reading great things about the M50s on here, which is why I went with them to begin with. The only problem I have with them is that they are a little uncomfortable. I have a big head and wear glasses, not a good combo for circumaural cans. The M50s clamp pretty dang hard and have shallow cups, which tends to be a little uncomfortable. Does this get better with time, or should I assume that if I am having problems now I will hate the cans after a few hours of listening?
I wanted to try the DT770s because I heard they are comfortable, which they are. The only problem is that they cost considerably more than the M50s and I can't use my reward points on them. We are talking $35 out of pocket for the M50s on Amazon vs. $180 in-store for the DT770s. I have to return one, keeping both is not an option. I don't want to keep the M50s only to hate them after a month because they still feel uncomfortable, but I don't want to spend all that money on the DT770s if the M50s will break in and become more comfortable.
I am running my current setup mostly unamped. If I am listening to vinyl, the headphones are amped, but if not the cans are running from my Macbook or my iPod classic. I rip all of my music to at least 320k MP3 or Apple Lossless when possible. I listen to a very wide variety of music from Dylan to Nirvana to Rap and everything in between. Bass isn't a huge concern of mine at all. I just want something comfortable, high quality, and excellent sounding. Amping my cans isn't really an option either, as I need them to be portable and I don't want to carry around an amp, no matter how compact. I have found that the 80ohm DT770s don't seem to have a problem being driven by an iPod, albeit at a higher volume than is needed for the M50s.
So whats my problem? Well I need to know if the $35 vs. $180 is worth the difference in comfort between the M50s and the DT770s. Right now they both sound great to me, though they each have their nuances that I can appreciate. If you own one or both of the headphones, please let me know what your experiences have been. It would also be nice to hear from other larger headed glasses wearing audiophiles!
Thanks for the help!!
