Sugano-san
- May 19, 2003
I read in one of the more respectable German hifi mags that you should always use the balanced output of the Benchmark DAC, even if your system is single-ended. In that case you should use wires that connect the DAC's balanced outputs to your systems's single-ended inputs.
Reason: Apparently the DAC1 uses a completely balanced signal processing internally, and the signal that goes to the single-ended outputs is de-balanced by means of substandard ICs.
1.) Has anyone here heard the same?
2.) Has anyone here experienced the same, i.e. that (in the case of the DAC1) balanced-to-single-ended sounds better than single-ended-to-single-ended?
Thanks.
Thanks.
