Battery-powered USB hub?
Feb 5, 2013 at 10:34 PM Thread Starter Post #1 of 10
CJG888
Braunschweig
Does anyone know of a decent battery-powered USB hub which is currently available on Taobao or EBay?
Thank you.
Feb 6, 2013 at 4:58 AM Post #3 of 10
CJG888
Braunschweig
I've tried a battery-powered USB charger (basically a battery with a built-in charger), and am having problems with clicking noises. Do you have any specific recommendations regarding battery PSUs (brand, availability?).
Feb 6, 2013 at 9:21 PM Post #5 of 10
CJG888
Braunschweig
When the D7 is powered via a powered hub connected to the USB charger (battery powered), and IEMs are connected directly to the D7's headphone socket, a regular ticking noise is heard in the background, regardless of the volume setting or of whether a source (iPad) is connected or not. The ticking disappears when the charger is replaced with a 5V "wall wart".
Feb 16, 2013 at 11:49 AM Post #7 of 10
dcginc
I'm looking for this solution too. So I can power up DAC/amp combo w an i pad
Feb 16, 2013 at 12:01 PM Post #8 of 10
dcginc
Anybody try this one?
http://www.cyberpowersystems.com/products/accessories/usb_hubs/cph420p.html?selectedTabId=overview&imageI=#tab-box
Feb 16, 2013 at 2:24 PM Post #9 of 10
dcginc
some other hi fi blog mentioned this self powered usb hub.. http://vaunix.com/products/high-quality-usb-hub/overview.cfm
Mar 18, 2017 at 2:43 PM Post #10 of 10
arong7
Hi, Im new here, this is a great forum. I got here because I was googling
"battery pack usb hub" I read this but it didnt solve my problem.
http://www.head-fi.org/t/649810/battery-powered-usb-hub
I have these battery, a laptop and a this usb hub.
I want to know if it all work together. I want to supply the usb hub with the battery cause
I need to connect several usb devices on the go. The devices I want to connect are
gsm modems.
https://www.amazon.com/Liztek-7-Port-Smart-Charging-Ports/dp/B00O92TNSA/ref=sr_1_49?s=wireless&ie=UTF8&qid=1489862138&sr=1-49&keywords=powered+usb+2.0+hub
https://www.amazon.com/100-PERCENT-MPU951BK-Smartphones-Activate/dp/B01LB3U8X8/ref=sr_1_1?s=wireless&ie=UTF8&qid=1489861873&sr=1-1&keywords=outlet+battery+pack
https://www.amazon.com/100-PERCENT-Charging-Smartphones-Take-out/dp/B01MCRUC2O/ref=sr_1_2?s=wireless&ie=UTF8&qid=1489861873&sr=1-2&keywords=outlet+battery+pack
If you have another suggestion to solve my problem it would be great.
what should I buy ?
Thanks in advanced
