Basic lightweight MMCX cable
Jun 17, 2020 at 7:03 AM Thread Starter Post #1 of 4
Lebowsky
.eu
Can someone please recommend a very basic MMCX cable? It needs to be lightweight, without mic or volume control, and without pre-curved memory wire.
I would be using it with Sony XBA-N3, the stock cable pulls too much on the earphones (mainly because of volume control), and using the clip is not always possible, especially in summer!
Thanks!
Jun 17, 2020 at 10:55 AM Post #2 of 4
Jun 17, 2020 at 7:44 PM Post #4 of 4
If you're ok with soft ear hooks (no wire), this nicehck cable is well recommended.
https://m.aliexpress.com/item/32971728152.html
I'd browse or search through this thread:
https://www.head-fi.org/threads/low...wise-bang-for-buck-cable-thread.891911/unread
Another good source is:
https://www.head-fi.org/threads/resistance-of-cables-pics-comments-and-links.907998/
thanks for those, I'll defintiely look those threads up!
If you want a super-thin (almost like it is not there) cable, check out the Linum cable line here, with BaX and Music being the cheapest:
https://www.linum.dk/shop/buy-now/
very interesting, but very expensive.. can't really justify such high cost with my medium range IEM unfortunately :frowning2:
I should have said in my first post - I'm looking for something around ~ $50
After lots of searching, MEE audio seems to have an interesting cable... we'll dome some more research on that!
