Bang & Olufsen BeoPlay H6 Discussion Thread
Jun 28, 2017 at 1:53 AM Post #1,801 of 2,818
IgeNeLL
Jun 29, 2017 at 8:31 PM Post #1,803 of 2,818
IgeNeLL
Does any one use it, My lovely version.
I have tried H6 with some dac/amp and find the most suitable is grace design M9xx. But when you have higher amp like HDVD800 or Audio GD M9 it will benefit very much, nice to try.
I would like to give my impression but it will take times, wait for me :)
Jun 30, 2017 at 3:49 AM Post #1,805 of 2,818
yaccobo
Zurich, Switzerland
You won't go wrong with the Belkin Mixit Aux Cables. They fit the H6 socket perfectly...
Just for clarification, are you talking about the 1st or 2nd generation H6? I have the 2nd gen H6 and before buying this cable i want to be sure they’ll match. Thanks!
Jun 30, 2017 at 5:55 AM Post #1,807 of 2,818
WoodyLuvr
siam
Jun 30, 2017 at 6:22 AM Post #1,808 of 2,818
mbwilson111
I have that same Belkin cable on my gen2 H6... I bought the grey one because my headphones have the natural color pads and the grey matches the plastic housing.
Here is the photo that I shared a few pages back. You can see how it connects.
Jul 1, 2017 at 9:50 AM Post #1,810 of 2,818
Dickies
I've not heard any of the first grou
I still don't understand how good are the H6 Gen2.
Are they on the level of cans like HD650,DT880,Denon D2000 or are they on the level of Beats Solo2,Senn Momentums,Sony MDR 1A??
I've not heard the first group of you mentioned, I've heard all of the second group (assuming you're talking about wired momentums)
and I prefer the h6 gen1 and gen2 to all of the second group you mention.
Jul 1, 2017 at 8:34 PM Post #1,811 of 2,818
IgeNeLL
The first group is fullsize desk so it is not compatible to compare and the characteristic of each is too different
The other group i'm sure that H6 gen 2 is better.
If you want to compare, I can suggest some: MH40, P7, H6, 1A, ... It is portable fullsize.
Jul 5, 2017 at 1:25 AM Post #1,812 of 2,818
rasmushorn
Denmark
Thanks for the recommendation for the case for H6. It looks perfect!
Jul 9, 2017 at 6:57 AM Post #1,813 of 2,818
kadamian
The main problem with H6 is the price. It is too low. They should be priced at least at 1k$ for people stop asking and comparing the h6 to the likes of hd650 and others...simply because the h6 really sound astonishingly good. So when you hear the H6 and then look at the price you start scratching your head and asking question whether the +1k$ asking price of inferior sounding headphone can be called "normal".
This is how good the H6 really are.
Jul 10, 2017 at 12:56 AM Post #1,814 of 2,818
gemNeye
Midwest USA
Jul 10, 2017 at 2:35 AM Post #1,815 of 2,818
MixMasterMan
Short answer? - Yes. They are probably the most balanced and rounded of the portable over the ear cans. I love the MDR-1A, btw. They are closest to those, but with better low frequency balance and clarity.
