maestro
- Mar 17, 2003
I just got an AV710 and I love it. However, I am getting a lot of line noise when connected to the rear output as described in one of the threads here. However, I believe it has nothing to do with the sound card as the noise still exists even when the card is muted.
The reason for the noise is that my receiver is 20' away from the computer and will not be moved.
Can you output through the SPID/F when in high quality mode on the card? If so, will there be problems running an optical cable 20'?
If I should just stick with what I have, does anyone recommend any good cables to use to reduce the noise?
Thanks.
Thanks.
