av710- Master Volume for left channel doesnt work
Jun 30, 2004 at 3:11 AM Thread Starter Post #1 of 5
Smurf
I'm using the latest drivers and for some reason the volume of my left channel is stuck at 50% the back speaker volume changes it, but not the master volume. In my control pannel and in the audio deck! Anyone had these issues? I turn the 'master volume' down all the way and I still hear the left channel! As of now I've resorted to runing the right channels volume down to 50%.
Jun 30, 2004 at 8:04 AM Post #3 of 5
Also you can use the regular 2 channel mode and still get sound from the back channels if you don't touch the other mode (doing so usually needs a reboot to fix). In regular mode the bug doesn't exist and 96KHz playback and high quality sound through Wolfson DAC is still available (although you need 96KHz source or resampling in your software).
Jun 30, 2004 at 8:55 AM Post #4 of 5
Even when I do go into my control pannel and change the left volume it doesn't change at all. If I turn the volume in there down all the way I still get 50% volume out of my left channel.
