MajinWu
- Apr 20, 2003
I just got my A900s a few days ago. First I tried plugging them directly to my Chaintech AV-710's high quality output jack (the black one called 7/8 jack) and used Foobar to play at 96000hz and 24bit padded to 32bit with Kernel Streaming. It sounds very anemic compared to the normal output jack (green one). I could use the green one and play music at normal sampling rates, but it's not as clear as the 7/8 jack, even though the green jack has more bass). So what I did was plug my Klipsch Promedia 4.1s into the 7/8 jack (just the green plug into the black jack) and plugged the A900s into the Promedia's headphone jack. The sound is a lot fuller. Is this an amp effect? Is the quality as good as maybe a Cmoy would be through the same source?
