NinjaNennyNing
- Jan 25, 2017
I recently bought Sony's MDR-1000X, but I haven't been able to find any aux cables that fit aside from the one supplied in the box with them.
The plug housing of the supplied cable is about 5.25 mm in diameter for about 2.5 mm behind the plug to allow it to fit into the cutout in the headphones. The smallest cable I've been able to find has a housing with a 5.5 mm diameter, but it's a tight fit and I'm concerned the force might eventually break the jack.
Has anyone found a compatible cable for these?
